12x antenna
HI all, any one know the link to Horizon site that shows the proper way the antenna goes, straight or kinked, for the 12x.
Thanks Rcpete PS, I think it is straight. |
RE: 12x antenna
RE: 12x antenna
1 Attachment(s)
This picture is off the Horizon Site. It shows a guy holding the transmitter with the antenna pointed out, just like as if he was taking a Leak while looking a bit constipated. I sure don't hold my transmitter like that, or at least I hope I don't.</p> |
RE: 12x antenna
ORIGINAL: Kriptonic69 This picture is off the Horizon Site. It shows a guy holding the transmitter with the antenna pointed out, just like as if he was taking a Leak while looking a bit constipated. I sure don't hold my transmitter like that, or at least I hope I don't.</p> hahahaha my thoughts exactly .. he does need some laxation stuff... http://www.rcuniverse.com/forum/js/f...sn/devious.gif |
RE: 12x antenna
<div style="margin: 0cm 0cm 10pt">I disagree with this completely.</div><div style="margin: 0cm 0cm 10pt"></div><div style="margin: 0cm 0cm 10pt">Pos 1 and 3 are sort of acceptable but who the hell flys like that?</div><div style="margin: 0cm 0cm 10pt">Pos 2 is the most common position, and to quote Horizon</div><div style="margin: 0cm 0cm 10pt">“ a cone of silence” directly off the end if the TX.</div><div style="margin: 0cm 0cm 10pt">So why recommend a position with that ‘cone’ pointing where you fly?</div><div style="margin: 0cm 0cm 10pt">If you check the JR site they recommend the aerial facing down at 45 deg.</div><div style="margin: 0cm 0cm 10pt"></div><div style="margin: 0cm 0cm 10pt">Paul</div>
RE: 12x antenna
ORIGINAL: GrayUK .........why recommend a position with that ‘cone’ pointing where you fly? |
RE: 12x antenna
ORIGINAL: GrayUK <div style="margin: 0cm 0cm 10pt">I disagree with this completely.</div><div style="margin: 0cm 0cm 10pt"></div><div style="margin: 0cm 0cm 10pt">Pos 1 and 3 are sort of acceptable but who the hell flys like that?</div><div style="margin: 0cm 0cm 10pt">Pos 2 is the most common position, and to quote Horizon</div><div style="margin: 0cm 0cm 10pt">“ a cone of silence” directly off the end if the TX.</div><div style="margin: 0cm 0cm 10pt">So why recommend a position with that ‘cone’ pointing where you fly?</div><div style="margin: 0cm 0cm 10pt">If you check the JR site they recommend the aerial facing down at 45 deg.</div><div style="margin: 0cm 0cm 10pt"></div><div style="margin: 0cm 0cm 10pt">Paul</div> Phil. |
| All times are GMT -8. The time now is 05:53 PM. |
