servo-ds 8611a ds 8411
i lost a 8611a took a sh-t can i run a ds8411 on my elevators with a ds8611a will it be ok?????????????????????????/
RE: servo-ds 8611a ds 8411
You need to give more information
Plane? Are you intending to mix servo styles/sizes on a control surface?...I hope not, that's what I get from your question. |
f16 jet no mixing
I wish I could be of more help at the moment, but what's the scale? |
1/8 scale
Scott,
never mix match servo's on the same axis. there are prop-ups that will let you do it but if you have to prop it up, it's a weak link. Is your jet worth no more than a matching servo??? Good luck Roy |
You could go down to 8411's without any issue in flight performance. I would not use one 8411 on one side and one 8611A on the other.
thanks john thats what i meant sorry guys
