Kerosene pump
HI all, looking for a kerosene pump, PQ-12, 24 volt(001-240003).
I heard Master Care has them, but can"t find it on their site. Any help would be appreciated. Rcpete |
RE: Kerosene pump
you can get one for 60$ at jeresey modeler:
http://www.jerseymodeler.com/id29.html i think it is good price, with warenty as they do stand beyond thier products hope it helps |
RE: Kerosene pump
RE: Kerosene pump
McMaster Carr
http://www.mcmaster.com/#8220k44/=2xdvvg |
RE: Kerosene pump
RE: Kerosene pump
Oops, I missed the 24 volt.......why do you want or need 24 volt ?
Angus |
RE: Kerosene pump
HI Angus, since these pumps are so powerful, even Jersey Modeler advices using a lower voltage on the 12 volt pump (7.2v). Since I use 12v for all my gear, I"ll use 12v on the 24v pump, as I "ve seen others do recently, with success..
Rcpete |
RE: Kerosene pump
AAAHHHHHH now that makes some sense, if I put an ounce of thought into both my fuel jugs i would realize that I run 7.4v on both of the 12v pumps.....duh :D:D
If the weather ever improves I'll call Angus |
RE: Kerosene pump
RE: Kerosene pump
Pete,
Just order the PQ-24 directly from Greylor. That's the one I have. I run it on 12 volts and it's been working fine for the past 3 years. http://www.smartcart.com/greylor7/cg...item_num=PQ-24 Joe |
| All times are GMT -8. The time now is 06:55 AM. |
