RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Hot Spot JetCat P80 turbine mount? (https://www.rcuniverse.com/forum/rc-jets-120/8998904-hot-spot-jetcat-p80-turbine-mount.html)
warbird51 08-07-2009 10:19 PM
I am helping a buddy with a Hot Spot assembly and as I understand it there was a special turbine mount to install a JetCat P80 to the fuselage. I have a stock P80 mount and I want to know what the difference between the stock and the custom mount that was available for the Hot Spot? Or, if anyone knows where I can get the special mount, that would help also. JetCat doesn't have any left. Or, is there a way to modify the stock mount for use?
Wayne
SJN 08-08-2009 02:53 AM
RE: Hot Spot JetCat P80 turbine mount?
1 Attachment(s)
I think my friend used the stock mount in his with no mods.
BaldEagel 08-08-2009 05:17 AM
The special mount is what they called the Kangaroo mount, it attaches to the airframe from the bottom i.e. no side lugs, I had trouble getting hold of one, but eventually found one in stock in Holland, keep searching on Google, if I remember correctly JetCat US did have one some time ago and so did Dreamworks, but as they are US I could not use them.
Hope that helps.
Mike
roo 08-08-2009 05:39 AM
There was a special mount and it is different to the original one that comes with the engine. It is also coloured purple. It is not a big job to modify the original but it does not look as neat. Paul.
Duncan 08-08-2009 12:05 PM
The Hotspot mount has side lugs. It's anodised purple and I bought one last November from jetline in the UK, I tried to find one everywhere and that was the only place that had them in stock
ThomasP 08-08-2009 12:34 PM
http://www.jetlinemodels.co.uk/
Regards,
Alistair
Newark, Nottinghamshire, England
warbird51 08-08-2009 01:59 PM
What is the difference between the stock JetCat mount and the Jetline mount shown above? It looks like the JetCat mount except for the color. Is the thrust line different?
Thanks for all the info.
Wayne
cmjets 08-08-2009 03:03 PM
Hello::)
I think that you only need increase the height of the turbine with your mount 3 or 4mm, because the nuts hit the fuselage.
Regards from Spain.;)
Carlos.
__________________________
http://cmjets.blogspot.com/
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
