Turbine oil
I can’t seem to find any aero shell 500, this is what Airplane oils.com can get. Is any one using any one of these oils .
BP 2380: PRF - 23699F - STD Mobil 254: PRF - 23699 - HTS AeroShell 560: PRF - 23699 Class HTS Thanks George |
RE: Turbine oil
All of those listed will work.
V.. |
RE: Turbine oil
I use 2380 and 2389 with no issues I have some Mobil Jet that I am going to try next, should be no problem.
RE: Turbine oil
The 2380 has been widely used.
RE: Turbine oil
been using 254 exclusively since 2004, never had one issue
RE: Turbine oil
When you guys state what oil you are using, It would be helpful to know what turbine you are using it in. I have been using Aeroshell 500 exclusively for 10 years. I have about 10 cans left and I am planning ahead if I cant get it anymore. The Oil Store isa only 45 minutes from my house!
Thanks in advance |
RE: Turbine oil
ORIGINAL: G4guy When you guys state what oil you are using, It would be helpful to know what turbine you are using it in. I have been using Aeroshell 500 exclusively for 10 years. I have about 10 cans left and I am planning ahead if I cant get it anymore. The Oil Store isa only 45 minutes from my house! Thanks in advance Jetcat P-120 Jet Central Rhino |
RE: Turbine oil
used Mobile Jet ll 254 in
T-500 P-60 P-60SE P-70 P-120SE jetcentral falcon simjet 1200 pst-600r |
RE: Turbine oil
UPDATE Bob Wilcox of JetCat said any oil with the rating of 23699 will work. George
RE: Turbine oil
I don't understand why you can't find Aeroshell 500. A simple Google search found these:
http://www.mil-specproducts.com/prod...FRYiagodk1b0oA http://www.aircraftspruce.com/catalo...s/shell500.php http://oilstore.stores.yahoo.net/aerturoil500.html http://www.bvmjets.com/Pages/Catalog/oil.htm http://store.skymartsales.com/aerosh...e-2500241.html |
RE: Turbine oil
Try to order it!
RE: Turbine oil
Did that search a month ago because you can't get Aeroshell 500 from the Oil Store right now and Gordon & I got the last 2 cases from Airplane Oil. The only issue with the other places is price, which goes anywhere from $30 to over $75 more per case than what we paid. Easy to find the oil, hard to find a good price.
RE: Turbine oil
Try this place.. Great price $ 208.09 a case !!!
www.airplaneoil.com go to search, type in aeroshell 500. they sell it by the Qt. also... Price jumps alot !!! Danno |
RE: Turbine oil
When I told with CARLOS ( RTI ), about that, in your experience MOBIL JET II, was the best, low carbonization in combustion chamber, I use MOBIL JET II since 2002. my opinion. hope help JOSE [8D] |
RE: Turbine oil
aeroshell 560 will work just fine
RE: Turbine oil
I've heard from Jetcat and AMT that they like the shell 500. Clean as pin when they open it up !!!
Danno |
RE: Turbine oil
ORIGINAL: aquaskiman UPDATE Bob Wilcox of JetCat said any oil with the rating of 23699 will work. George I've never used anything but the Hatco Corp green can 23699. |
RE: Turbine oil
Airplaneoil.com does not have aeroshell 500 That is who I am dealing with. George
RE: Turbine oil
Do some studying up on Mobile DTE oil. I did and I will no longer use the dangerous stuff that has always been used. The "normal" oil is not very human friendly. The DTE is way cheaper and from the reports I have heard here at RCU works just as well as the other stuff.
Read up on it and see what you think? |
RE: Turbine oil
ORIGINAL: aquaskiman Airplaneoil.com does not have aeroshell 500 That is who I am dealing with. George Maybe thats why their price is so good... If I were them and didn't have it, I'd sell it for $ 100.00 a case.:D |
RE: Turbine oil
This is a copy of the e-mail that Tom sent me.
ello George, Re: Order for AirplaneOil.com #2041 I have lately heard that the supplier that packages the AeroShell 500 has gone bankrupt and is still working but is extremely back logged. This is an alternative that I just found out about last week. You might check with others to verify what I have been hearing or with the engine manufacturer. This is what I have. I'm reading off each of the cartons. The PRF- 23699 is the Mil Spec # and as I understand it other Model Jet folks are using any one of the products listed below. BP 2380: PRF - 23699F - STD Mobil 254: PRF - 23699 - HTS AeroShell 560: PRF - 23699 Class HTS Let me know your thoughts. As I mentioned I will be out of the country but you could reach my son Josh King at 314-616-2487 or his email is [email protected]. Thank you! Tom King President AirplaneOil.Com 314-616-2487 |
RE: Turbine oil
I have been using the 2380 for several years. Ram 750, Ram 1000 and for past 2+ years, 2 Rhinos. Never a problem related to oil
