RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   aircraft wheel brakes (https://www.rcuniverse.com/forum/rc-jets-120/9076846-aircraft-wheel-brakes.html)
jamiechip 09-07-2009 05:16 PM
1 Attachment(s)
has anyone out there have any pics of a air powered brake for the wheels of the jets or break downs to explain how they work i am looking to machine up my own smaller set for a small turbine project but really need some help i normaly would not worry about it but under australian rules i belive from what i have been told you must have brakes on all turbine jets so i feel that machineing up my own small set would be the way to go anyone that can help that would be great or sheed some light on the rules a little more
thanks
regards jamie
rcjetsaok 09-07-2009 05:32 PM
RE: aircraft wheel brakes
BVM.... The only way to fly !!!!! (and stop ). His website some pics, but you might want to contact one of his Reps for more info.. You get what you pay for !!
Good luck,
Danno
KC36330 09-07-2009 05:33 PM
http://www.bvmjets.com/Accessories/wb-howitworks.jpg
limeybob 09-07-2009 06:59 PM
O-ring has to be a tight fit in the groove. Use a lubricant to roll them in.
Had to retrofit some Chinese brakes, took three tries to get the right size.
bob
jamiechip 09-07-2009 07:16 PM
thanks for that info looks like something easy enough to manufacture ill give it a go i thought it would be as simple as that ill update on how i go with it
jamiechip 09-07-2009 07:18 PM
in some of the other pics there are diferent types of these brakes ofcourse the oring seams the easiest is there any other way of doing it that is easy enough to manufacture ?
PaulD 09-07-2009 07:49 PM
Make sure you get the surface finish right in the 0-ring grove or they'll be leakin' in no time.
I like the BVM idea as there is no axial load on the wheel hubs. I have a set of Behotec gear and although the brakes work very well they do push sideways (axial) on the wheels and do not completely free up right away.
PaulD
roger.alli 09-07-2009 08:04 PM
ORIGINAL: jamiechip
thanks
regards jamie
Hi Jamie,
The current Australian MAAA turbine operation rules here in Australia; http://www.maaa.asn.au/maaa/mop/proc...Feb%202003.pdf
These rules do not specify brakes as a requirement, however they are a very good idea on any turbine model. I use BVM brakes, and they work very well. (I wish I had the skill to maunfacture my own).. Good luck with your project.
Roger
jamiechip 09-09-2009 05:17 AM
after talking to a mate he said that the model must not roll with static thrust wich makes sence of course and i think brakes are a good option
does anyone know where to find the liquid rubber for the tyres i know they are molded from liquid i just beed to fing it a bit of searching has turned up nothing any help would be great
bcovish 09-09-2009 05:26 AM
Do a google search "liquid rubber" and a lot comes up.
jamiechip 09-09-2009 06:13 AM
i do the search all i get is compunds to do coatings not for the actual tyres if anyone knows what they call the rubber that might help
Glen Roberts 09-09-2009 09:32 AM
Tom Cook at JMP has the best brakes.
Glen.
BaldEagel 09-09-2009 01:04 PM
The problem with O ring brakes is they only push out in the area of the piston so the braking effect is only in two or maybe four places around the wheel, have a look at the Digitech brakes they are a bladder which pushes a plate onto a disc of brake material inside the wheel, only perceived problem is that your wheel could be pushed off it not fitted correctly.
Mike
Eric Maydon 09-09-2009 03:42 PM
Hi there
Exactly the same system as Glennis Aircraft uses. Faultless after many years service.
Eric
jamiechip 09-09-2009 04:03 PM
anyone got pics of this system or break down pics on how they work and go together
Vincent 09-09-2009 04:34 PM
Mike,
Intarico i believe uses three pistons that push up against the oring. They do not work well on the bigger wheels i have found. BVM and some others use just an oring and it expands all the way around to put equal pressure.
V..
lov2flyrc 09-09-2009 06:06 PM
Airpower wheels ("Digitech" are Airpower wheels) use a bladder as shown below to press their disc outward into the wheel hub. Very simple but effective unit.
http://www.airpowernet.com/twe3/imag...mages/29_0.jpg
http://www.airpowernet.com/twe3/imag...mages/26_0.jpg
rcpete347 09-09-2009 07:14 PM
1 Attachment(s)
Intarico does use 3 pistons that push against a rubber band and the wheel hub. I think they are useless on larger wheels, like my Comp Arf Lightning.
Rcpete
causeitflies 09-09-2009 10:38 PM
1 Attachment(s)
They are adequate for the smaller Flash but the ones I really like are the Skymaster disk brakes. (Sorry for the out of focus. I only took one pic real quick while working on the plane)
jamiechip 09-12-2009 05:35 PM
one thing im still trying to find is the rubber for makeing wheels is there anyone out there that has made some or know of what rubber and where to find it ?
Pipecleaner 09-14-2009 05:47 AM
Hi,
I have a lot of experiences from O-ring brakes. If manufcatured with right tolerances the performance is so good that you will get flat tires!!
Use the O-ring manufactures data tabel to get the right measurements. Make sure the surface where the O-ring will be busy is very smoth. After turning the hub (slot where O-ring will be busy) use fine grid and after that polish the surface with some "polishing rubbing blend". I recomend the tolerances from the O-ring to the slot in the wheel hub to be -2 to -3 /10 mm.
Lubricate the O-ring whit some cristaline stuff.
Pipe
