RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Making a Solid Nose wheel (https://www.rcuniverse.com/forum/rc-jets-120/9185546-making-solid-nose-wheel.html)
limeybob 10-19-2009 01:20 PM
1 Attachment(s)
Being desperate for a solid nose wheel ,I decided to make one.
Took a Dubro 2.5" dia soft wheel, cut a half inch slit in the top, pried it open with a piece of scrap wood and poured in warmed epoxy.
Its nice and solid.
We will see if it works.
Bob
KC36330 10-19-2009 01:21 PM
RE: Making a Solid Nose wheel
did you balance it?
limeybob 10-19-2009 01:53 PM
Good thought , I'll check that
Bob
limeybob 10-19-2009 02:11 PM
It is heavier on one side, going to make another one with a mixture of micro ballons.
bob
KC36330 10-19-2009 02:17 PM
try chucking it up in a drill with an axle and spinning it fast and see if you get vibration, i had a solid tire that vibrated bad on the take off roll, replaced it and problem solved, i then cut the tire open and found a large air pocket in the material. now i spin all tires/rims before mounting them on a jet.
