RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Airpower Inflatable Tires Question (https://www.rcuniverse.com/forum/rc-jets-120/9218073-airpower-inflatable-tires-question.html)
Fighting Falcon 10-31-2009 03:33 PM
1 Attachment(s)
Sorry guys for what might sound like a dumb question. I just Bought a Set of Airpower Inflatable Tires and there were no instructions in the package. There is no fill valve or connector (inlet) ment to attach any handpump or air compressor.
Question..... Are these tires really inflatable? If so, how do I go about filling them up?, What pressure figures should I look
Thanks in advance...... I am sorry for what is probably a very trivial quention.
regards, Jose E. Lopez
derrickxp8103 10-31-2009 03:42 PM
RE: Airpower Inflatable Tires Question
Hello,
There is a small hole where the air goes in on one side near the bolts that hold the aluminium wheels together. I use my large aircompressor with a blow gun that has a small air outlet end on it. You have to set the compressor at @ 120 psi to get air past the fitting (small hole) on the wheel. Don't put too much air.....they might rupture. I put just enough air in untill the tire feels and looks right.
I filled mine tires up 2 months ago and they still holding air !!
So far I think they are good tires.
Derrick
c_makhija 10-31-2009 05:24 PM
Hi Falcon,
I use a hand pump and inflate to about 60 to 70 psi, but like derik said just press the tyres and they should feel right. If you over inflate, they become rock hard. I use the ZAP cyno bottle extentions, cut it appox till the nozzle fits into the hole on the rim. On the other end of the plastic extention i push fit a 4 mm festo tube which is attached to the pump.
Chaitanya.
Fighting Falcon 10-31-2009 07:15 PM
Ok Derrick and Chaitanya; just did as you said and I got it worked out. Thanks for your time and happy flying..
Regards
flyexperimental 10-31-2009 07:29 PM
Measure the diameter of tires to check for identical pressure.
Guillermo Ibanez 10-31-2009 10:59 PM
ORIGINAL: Fighting Falcon
Regards
Hey Falcon, go to this link.....
http://www.skymasterjet.com/wheels.htm
Saludos desde Barranquilla, Colombia........http://www.rcuniverse.com/forum/js/f...ular_smile.gif
