KingCat CROW ??
Downloaded 'KingCat Datasafe.TTK' file and 'Crow Instructions' from BVM website.
When I download the Datasafe file to my JR10X the first P-Mix #51 doesn't match the Crow setup instructions. Datasafe file has it as a 'RUDD>AILE' Mix. The Crow instructions have it as a 'FLAP>FLAP' Mix. The CROW seems to work but when I try to do the first Crow instruction (Disabling flap side lever) then my flap travel really seems to decease. The Crow movement still seems the same but the Flap Full-Up position doesn't seem correct. I've tried changing P-Mix#51 to a 'Flap>Flap' Mix with No change. Any ideas? THANKS, TOM |
RE: KingCat CROW ??
I did mine by the BVM instructions... not the download. I think you need to go into travel adjust to get the flap movement the way you want it after inhibiting the lever... And perhaps sub-trim...can't recall for sure on that. On the written Bvm instructions he addresses this issue. Print the instructions and read slowly and carefully. I had to read it a couple of times to get it !!!
Good luck, Danno |
| All times are GMT -8. The time now is 03:13 AM. |
