What size engine - A poll
What size engine would you most prefer to have?
Do you like 'em small or are you a Mega dude? Do you want the whole thing to be blingy or just run-of-the-mill regular. I've also added an option for the financially challenged (like me :D) Vote away! |
RE: What size engine - A poll
You should add the 20 lb & 30 Lb class to your list;)
ORIGINAL: RCISFUN You should add the 20 lb & 30 Lb class to your list;) Too many options. Like going into a restaurant and having to spend the next 30 minutes reading the menu :) I'll add a 33lb option for those who like'm big (but not really). |
28 to 30 #
40lb engine in a 28# case also same weight ;) This type of engine works in any 25lb jets.
I like the 40lb thrust class overall, but right now I had to pick mega monster because that's what I'm after!
We need a Jet Central Rhino thrust class sized like a Falcon. Kind of like a Rabbit technology based Falcon.
You're saying you want more thrust in smaller package, right? Even if the fuel draw is horrible?
Very generally a 40# engine in a 30# case will draw fuel like a 50# engine. |
ORIGINAL: erazz You're saying you want more thrust in smaller package, right? YES Even if the fuel draw is horrible? NO |
They always say that small ones work fine. Don't let them fool you. They always like the larger ones better.
ORIGINAL: erazz You're saying you want more thrust in smaller package, right? Even if the fuel draw is horrible? Very generally a 40# engine in a 30# case will draw fuel like a 50# engine. |
ORIGINAL: erazz You're saying you want more thrust in smaller package, right? Even if the fuel draw is horrible? Very generally a 40# engine in a 30# case will draw fuel like a 50# engine. Well.. A 25lb# engine size in a JL L-39 (Example 40#thrust for a L-39 or a S/M F-18c ) will put your throttle setting above haft the whole flight. But with a bigger engine your throttle just above idle & better fuel consumption. P.s In my opinion |
ORIGINAL: FalconWings We need a Jet Central Rhino thrust class sized like a Falcon. Kind of like a Rabbit technology based Falcon. Gaspar |
ORIGINAL: basimpsn ORIGINAL: erazz You're saying you want more thrust in smaller package, right? Even if the fuel draw is horrible? Very generally a 40# engine in a 30# case will draw fuel like a 50# engine. P.s In my opinion Hehe... Efficiency doesn't work that way. Consider 2 engines. Both 40# thrust. One has a 120mm dia case and one has 100mm. The larger diameter will have better efficiency. It will use less fuel to push the same thrust. I can understand why the thrust-to-weight or thrust-to-size numbers produce better sales. But on the efficiency side having a wide and short engine is much better. |
Good point ;)
1 Attachment(s)
Actually if you want more thrust.... :eek:
ORIGINAL: erazz ORIGINAL: basimpsn ORIGINAL: erazz You're saying you want more thrust in smaller package, right? Even if the fuel draw is horrible? Very generally a 40# engine in a 30# case will draw fuel like a 50# engine. P.s In my opinion Hehe... Efficiency doesn't work that way. Consider 2 engines. Both 40# thrust. One has a 120mm dia case and one has 100mm. The larger diameter will have better efficiency. It will use less fuel to push the same thrust. I can understand why the thrust-to-weight or thrust-to-size numbers produce better sales. But on the efficiency side having a wide and short engine is much better. Better thrust/weight and thrust/size is just evolution, look at how things have progressed in the 110mm class since the KJ66. You need to add a choice in the poll for those of us who don't have a particular size preference and it does not have to be cheap. :D Rob. |
1 Attachment(s)
Now thats what im talking about :D
I believe that for my budget, cheaper is better, even if that means having to modify the turbine to make more thrust. I Like buying cheap and experimenting, it puts more fun into the hobby.
1 Attachment(s)
Here's the turbine wheel for the new JetCat....
ORIGINAL: Harley Condra Here's the turbine wheel for the new JetCat.... PaulD |
More taste less filling :)
ORIGINAL: erazz ORIGINAL: basimpsn ORIGINAL: erazz You're saying you want more thrust in smaller package, right? Even if the fuel draw is horrible? Very generally a 40# engine in a 30# case will draw fuel like a 50# engine. P.s In my opinion Hehe... Efficiency doesn't work that way. Consider 2 engines. Both 40# thrust. One has a 120mm dia case and one has 100mm. The larger diameter will have better efficiency. It will use less fuel to push the same thrust. I can understand why the thrust-to-weight or thrust-to-size numbers produce better sales. But on the efficiency side having a wide and short engine is much better. Mainly the compressors and diffusors are radically different from the current CFD "optimised" designs. Combustors are simple but also very different. Andre Baird |
1 Attachment(s)
Paul,
The major players are able to invest in R&D effort that is unaffordable by the model engine companies. That wheel is from a Teledyne Continental 373-8C turbojet (940 Lbs of thrust, using 1980's technology). I was first introduced to this engine in around 1986. I took the attached launch photo in 2001 at Kom Aushim AFB, (Egyptian Air Force) southwest of Cairo, Egypt. The booster burns for 4.5 seconds, produces 4550Lbs (nominal) of thrust, when combined with the engine's 940 lbs of thrust, accelerates the UAV from zero airspeed to over 400 Kts at booster burnout and drop-off. The UAV weighs 2356 Lbs. gross. When the booster ignites, it is Hellfire and Brimstone!! |
Nice to see some variety here. I was starting to think that the P-200 was the only turbine in existence now. LOL
Eric |
[/quote] Model Turbine engines have a long way to go before they reach the level of perfomance that can and has already been achieved in 4'' diameter sizes. I have seen compression ratios of 6:1 and 300N thrust at FSC of 0.02 g/N/s in KJ sized package, using ceramic NGV and turbine, 600N with 2000 deg EGT. Mainly the compressors and diffusors are radically different from the current CFD ''optimised'' designs. Combustors are simple but also very different. Andre Baird [/quote] Will this technology make its way into model turbines and at what price? |
ORIGINAL: Bob R2 Model Turbine engines have a long way to go before they reach the level of perfomance that can and has already been achieved in 4'' diameter sizes. I have seen compression ratios of 6:1 and 300N thrust at FSC of 0.02 g/N/s in KJ sized package, using ceramic NGV and turbine, 600N with 2000 deg EGT. Mainly the compressors and diffusors are radically different from the current CFD ''optimised'' designs. Combustors are simple but also very different. Andre Baird Supersonic compressors are neat but have their limitations in our use. Some might |
ORIGINAL: Gaspar ORIGINAL: FalconWings We need a Jet Central Rhino thrust class sized like a Falcon. Kind of like a Rabbit technology based Falcon. Gaspar |
1 Attachment(s)
I prefer the teeny ones
You dont see this engines as much as the big ones. I build two 40rs engines ,they are 65mm o.d and i realy like them. i think they are much more fun to build then kj66 type |
ORIGINAL: Harley Condra Paul, The major players are able to invest in R&D effort that is unaffordable by the model engine companies. That wheel is from a Teledyne Continental 373-8C turbojet (940 Lbs of thrust, using 1980's technology). I was first introduced to this engine in around 1986. I took the attached launch photo in 2001 at Kom Aushim AFB, (Egyptian Air Force) southwest of Cairo, Egypt. The booster burns for 4.5 seconds, produces 4550Lbs (nominal) of thrust, when combined with the engine's 940 lbs of thrust, accelerates the UAV from zero airspeed to over 400 Kts at booster burnout and drop-off. The UAV weighs 2356 Lbs. gross. When the booster ignites, it is Hellfire and Brimstone!! Turbines of any size are COOL! [8D] |
ORIGINAL: erazz ORIGINAL: Bob R2 Model Turbine engines have a long way to go before they reach the level of perfomance that can and has already been achieved in 4'' diameter sizes. I have seen compression ratios of 6:1 and 300N thrust at FSC of 0.02 g/N/s in KJ sized package, using ceramic NGV and turbine, 600N with 2000 deg EGT. Mainly the compressors and diffusors are radically different from the current CFD ''optimised'' designs. Combustors are simple but also very different. Andre Baird Supersonic compressors are neat but have their limitations in our use. Some might The truth is current compressors barely works as it is. CFD tools available to the public are not good enough to hint at this. Their flow predictions are just way wrong. Andre |
ORIGINAL: Turbotronic A lot of reasearch has been done in the last 5 years which has turned conventional wisdom re compressor difussor design on its head. Some of it was known decades ago in the soviet block and has found its way into small missile engines. There is no reason why a reworked design with the technology we already use cannot produce 240N in a KJ size engine with close to half the fuel consumption. Its a question of know how. Add ceramics and youre talking 600N... ... I agree that there are some really nice innovations in impeller/diffuser designs. The problem (for us) is the use of ceramics. The current trend for turbines is to use Silicone Nitride and hot press it under high pressure (Hot Isostatic Pressing). While the process itself is not terribly expensive when compared to vacuum casting Inconel the bare materials are still very expensive. Plus any FOD that enters the engine will instantly turn that expensive turbine to dust. All in all the technology has not yet matured to the point we can reliably use ceramic turbines. I'm tinkering with this on-and-off. I promise to tell if I hit on anything :) As to the thrust figures - we're probably very close to the limit of what you can get in terms of thrust. 240N of thrust from a 70mm impeller will require almost 100% efficiency of the compressor stage. I doubt it's possible but I'd love to be proven wrong. Going to ceramics can increase thrust twofold. 600N from a Kj sized engine is probably not possible. The truth is current compressors barely works as it is. CFD tools available to the public are not good enough to hint at this. Their flow predictions are just way wrong. |
Erazz,
Its not a question of being proved wrong, its been done 15 years ago already. Ansys CFD gets it wrong too... New tools being develped right now are improving the situation but advances in laser velocitromy has divulged the true flow problems in non-axial compressors. While is is true that when the problem is set up incorrectly the best CFD fails, predicting initial conditions is very important. I know a lot about the subject, more than most small turbine builders, but it is nowhere near enough to form an opineon of what is possible and what not. So I rely on what has been done as a guide. I am reminded of the NASA propultion enginners that refused to believe a specification for a rocket motor developed in the 60's in the USSR. When they observed it during tests exceeding the spec they realized they were 40 years behind... Many military /research rockets now use this motor under licence in the USA... Andre Baird |
ORIGINAL: eric_monster Nice to see some variety here. I was starting to think that the P-200 was the only turbine in existence now. LOL Eric |
ORIGINAL: Didier ORIGINAL: eric_monster Nice to see some variety here. I was starting to think that the P-200 was the only turbine in existence now. LOL Eric |
ORIGINAL: Turbotronic ... I am reminded of the NASA propultion enginners that refused to believe a specification for a rocket motor developed in the 60's in the USSR. When they observed it during tests exceeding the spec they realized they were 40 years behind... Many military /research rockets now use this motor under licence in the USA... Yeah, engineers get stubborn. Good thing I'm not an engineer! :D BTW. Do you have any link or articles that deal with these new impellers and diffusers? I'd like to read about them. |
No public info has been released AFAIK from the specific company. I do have the info but I could not release it since it is copyrighted.
I can say that the diffusor has no vanes as we know them. The compressor is mixed flow and has a lot of backsweep right from the inducer end already. It runs at 120K and has a press ratio of 6:1 |
ORIGINAL: Turbotronic ORIGINAL: Didier ORIGINAL: eric_monster Nice to see some variety here. I was starting to think that the P-200 was the only turbine in existence now. LOL Eric |
| All times are GMT -8. The time now is 03:14 AM. |
