RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Fixing live hinges (https://www.rcuniverse.com/forum/rc-jets-120/9531172-fixing-live-hinges.html)
ECalderon 02-24-2010 06:54 AM
Fixing live hinges
Hi guys
I was checking out the wing of my jet yesterday and I saw that the live hinge of the aileron of one wing has broken a little less than an inch, and on the other wing it looks i will start breaking soon.
Is there an efficient way to fix this (using kevalr tape for example), or the only way is cutting it out and installing balsa blocks and Robart pin hinges?.
Thanks in advance for your input.
Eduardo
ECalderon 02-24-2010 04:36 PM
RE: Fixing live hinges
A lot of views, but no posts.
Anyone care to comment.
Regards
Eduardo
mselby 02-24-2010 04:55 PM
What jet? Do you have a photo of the area?
MaJ. Woody 02-24-2010 05:25 PM
I had the same thing happen to one of my ailerons on my L-39. During the repaint, I fixed it using a CA hinge glued underneath the hinge line. Be sure to have the aileron straight when you do this. Mine is rock solid now. You can't tell there was a problem since all the work is done inside the wing. I'll check to see if I took a picture.
rcjets_63 02-24-2010 05:48 PM
1 Attachment(s)
I had the same problem on my Skymaster Gripen on both the rudder and elevon. I cut the rudder out and installed CA-type hinges along the complete length (approx 6") of the hinge line. I only needed to install a couple of inches width of CA hinges on the elevon. As Dom says, make sure that the control surface is straight. Also, I'd suggest putting a bead of oil on both sides of the remaining live hinge line to prevent any CA from getting into the hinge line and hardening which will cause the it to quickly break.
Regards,
Jim
Gary Arthur 02-24-2010 08:07 PM
I had some carbon kevlar weave. I pulled the strands of kevlar out. Cut them about 1" long. Spread them out 90 degrees to the hinge line and hit them with thin CA. Works like a charm.
rcjetsaok 02-24-2010 08:11 PM
Pardon my ignorance, But what is a "Live Hinge" ?????? Never have heard that term before...[sm=confused.gif]
TIA,
Danno
noahb 02-24-2010 08:35 PM
its when the wing and aileron or other control surfaces use the skin of the wing as the hinge. As in composite airplanes like the comp arf flash. When you look at it, all you see is a crease where the hinge line is. Like folding a paper airplane and then bending an aileron on it or to that effect.
ECalderon 02-24-2010 09:04 PM
1 Attachment(s)
Thank you for your input, I would appreciate picture of the fix if you have them.
The jet is a Hawk and below are some photographs.
Regards
Eduardo
rcjetsaok 02-24-2010 10:09 PM
ORIGINAL: noahb
O.K. ... Got it !!! I built a couple of Eurosport's that use that... Just threw me cause I've never heard it called that before !!! Oh well, learn something new everyday !!!!... Thanks for the answer !!!
Danno
BaldEagel 02-25-2010 04:38 AM
If its just a small area that needs repair would a bead of silicon mastic work, I have used this as a hinge material only on some fair sized prop planes, but not on a fast jet, just thought as it may only be a small repair????
I know I am going to be shot at with this suggestion, but my sholders are broad.
Mike
cmjets 02-25-2010 06:28 AM
hello::)
I think that you can repair if use the same hinge nylon and cover it with fiber glass (for the botton side, not over the paint.:D )
For you are sure that the hinge run perfect you paint the center of the nylon with wax paint for childrens, do you know ? this way the epoxi not glue in the center and the hinge will work perfect.
you an see it here:
http://picasaweb.google.com/cmjets20...40381312378482
Try it. I hope work fine.
Regards from Spain;)
Carlos.
______________________________
http://cmjets.blogspot.com/
NightSwan 02-25-2010 08:23 AM
ORIGINAL: BaldEagel
Mike
No shots from me, good idea! In any case it will probably prevent the hinge from tearing more.
Hans
Jet Doctor 02-25-2010 08:44 AM
I had the same problem on my SM L39 elevator[:@]. I repaired it using a silicon bead on the inside of the hinge. I have not had a problem after that. This system is used by the glider guys as a hingeing system for awhile. I was doubtful and made up a test piece using two bit of scrap fibreglass and left it to cure for a week. There was no way that I or anybody else could pull the joint apart on a strip about 3 inches long. Try it for yourself and you will be amazed. :D
Gordon W 02-25-2010 12:04 PM
Here's a neat way to install CA hinges accurately:
http://www.rcuniverse.com/magazine/a...?article_id=55
Gordon
Silent Lamb 02-25-2010 12:06 PM
Link to silicone hinge - http://www.rc-soar.com/tech/silicone.htm
ECalderon 02-25-2010 07:42 PM
Thank you for your input guys
Eduardo
