EVSD-5U-PRO programming question
Hooked up my EVSD-5U-PRO and in Mode 2 everything seems to check out fine, with the exception of the final door close once the gear is reatracted. Every step appears to happing in about 2-3 seconds, however once the gear is up in takes much much longer for the doors to close behind them. Can this final setting be adjusted without messing up the rest of the programing?
RE: EVSD-5U-PRO programming question
Sean,
You can adjust the delay between the doors opening and the gear coming out, as well as the delay after the gear goes up and the doors closing behind them. Chad |
Thanks Chad...next question, how?
It's in the setting menu, I had to read the instructions to work mine out. There is a copy on the Airpower website :D
Duncan |
You mean I have to read the instructions!? :D Pulled them out and in about 2 mins had it working correctly. Thanks.
Lol no worries
| All times are GMT -8. The time now is 03:16 AM. |
