Tail pipes ?
hi there every one im looking into having my own tail pipe made up buy a mate but im unsure as to what thickness of stainless stell in comonly used i fully understand how to have it made but have found no info for steel thickness anyhelp would be greatly apreciated thanks
RE: Tail pipes ?
.10mm if you are brave and .20 if you want to be safe.
It can be hard to find too but if you google "shim steel" or "stainless shim" you will find it. I get mine from [link=http://www.repco-tech.co.uk/html/contactus/]Here[/link] Jason |
RE: Tail pipes ?
RE: Tail pipes ?
Jamie, If you are goning to go to the trouble to make one, I would go with 316 SS NOT 304. Roy
RE: Tail pipes ?
thanks for the help i have found some 316 i was gunna go with a twin wall pipe so what do you think of using the .127mm should be fine ? has anyone made ther own before ?
RE: Tail pipes ?
With a twin wall, .127mm will do. I have made very Very Similar many times. Roy
| All times are GMT -8. The time now is 07:40 PM. |
