Looking for RAM Manual
Does anyone have any copies I can be e-mailed of user manuals for any of the r a microjet turbine 1000 :)
Thanks Duncan |
ram manual
OZZ,
Go and get a copy of the FTE750 manual it is identical to the ram manual, minus the name changes etc. All the pertinent information is valid. Patrick. |
Why not E-mail Carlos at RTI and ask? His contact info is in the support forum.
FTE do not have the RAM 1000 online manual. Only the 750 plus.
RAM Manual
Any ideas where I can start looking??????
RAM Manual
OK let's get some clarification. If you look at the manuals for the 750P remote start and the 1000RS they are the same manual. Essentially the 750 Plus Remote Start and the 1000RS are the same engine.
Alright to make sure that I was not smoking something I went out to FTE's website, downloaded and read the manual again. The manual that is there is the same manual that was produced for the RAM 500, 750P, 1000 remote start engines from RAM. The only thing that has changed is the company name, some of the disclaimer stuff and the pictures. From page 16 to page 42( ?) the manual is identical except for pictures. So if you have one of the engines that I mentioned above you can use the FTE manual. Patrick. |
BTW OZZ - since you are in the UK, you may want to touch base with Jockjets (http://www.rcuniverse.com/member.php...fo&userid=9098) to be able to get RAM help that is fairly local to you (no need to deal with e.g. 8 hr time differences)
Gordon |
I have the PDF of the Manual when it was on Ram's web site.
Let me know and I can E-mail it to you. I is the one that is for the 750/1000 engine. Nic |
| All times are GMT -8. The time now is 05:36 AM. |
