RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   cheap electric air valve (https://www.rcuniverse.com/forum/rc-jets-120/9728794-cheap-electric-air-valve.html)
lord ultranoob 05-12-2010 12:02 PM
hi guys,
i'm working on a big project now and to make a long story short: i need a small solenoid valve (electric valve) for gas/air use.
now i have found that those things are used on rc jets and they are perfect for me.
now i'm looking for the cheapest one available working on 5 or 6 volt.
it does not really need programming shizzle, it just has to be normally closed and when i put voltage on it it has to open.
where can i find them?
thanks,
Basch
PaulD 05-12-2010 12:24 PM
RE: cheap electric air valve
XIOCY's prices are pretty good and also in EU so shipping should be reasonable for you:
http://www.xicoy.com/catalog/index.php?cPath=22
PaulD
lord ultranoob 05-12-2010 01:11 PM
yes i have seen them and they seem reasonable.
i have one question: what does ecu battery voltage mean?
any other cheap valves available?
Guillermo Ibanez 05-12-2010 02:03 PM
Is the battery that supply voltage to ECU. (Electronic Control Unit). ECU is the computer that control all turbine parameters in a radio controlled turbine jet.
