Important Announcement from Jetlegend regarding F20
To all whom it may concern:
As management of the Jetlegend company we were shocked to hear about the crashes of the F20’s, produced by our company. When we received the clear information we started an investigation. Jetlegend has been in model jet business for more than ten years; this is the first time that we are confronted with so many crashes of one model. After the first message reached us through our network, we initially suspected that the plane might have been overpowered or had seen unusual high G maneuvers beyond the limit of the plane. As the first information only mentioned one case it was regarded as an incident. As with any plane presented to the market, the F20 went through our standard test program. It had many test flights powered by a Jetcat P120 jet engine. After the crash report we had at least 20 test flights, pushing the test plane to the limits, but no signs of problems were detected. After following reports we tried to find the limits of the design and/or manufacturing and we then decided to use a Jetcat P160 to fly again. This test was done recently, in which the first 5 flights were ok, but in the 6th flight, during a high speed low pass, the plane developed a problem. After landing the investigation revealed that the elevator was loose, but fortunately was still working. It was concluded that the elevator couldn’t hold up at high speeds with a P160, but we wondered why the F20 with P120 was also having problems in the field as reported in a few customers’ cases. We checked the static thrust on the test plane and found that our P120, installed in the F20, gave significant less output than rated. We apology to the customers who crashed a F20 produced by us; the problem occurred due to our design and not having stressed it enough during testing. We do take responsibility for that. For those customers who crashed a Jetlegend produced F20, Jetlegend is offering a free-of-charge replacement by any model from the Jetlegend range, including landing gear. To those customers who bought our F20, but did not get it in the air yet, improved replacement parts will be send free-of-charge as soon as possible. We would like to apologize sincerely to all effected customers for the losses and for the missed flying fun. In order to avoid similar situation happening in the future, there will be review of construction methods and testing procedures. We, as Jetlegend management team, hope that above mentioned actions are sufficient to restore the confidence in our products and company and we wish all many successful model jet flights. Best regards Jetlegend management team |
RE: Important Announcement from Jetlegend regarding F20
Respect[sm=thumbup.gif]
Wow, this is a real milestone!
Frank |
This will do your Company no harm at all.
Talk about stepping up to the plate!
Well, that's some very honourable statement.
That is how things improve in every industry: .Characterize a product defect .Recognize the design mistake that is behind .Correct the problem and change the design process horizontally ( ie to all other products at the same level ) .Communicate about the problem ( and that's the most difficult part ) I am sure that people will recognize and appreciate your honesty in this affair and that your company will benefit from your transparency. |
ORIGINAL: DelGatoGrande Respect[sm=thumbup.gif] |
Nice to hear them do the right thing. Its refreshing and makes them stand out amongst others who have not. The only thing left for them to do is to make the guys who lost jets 100% restored. Anything less, doesn't really complete the deal. But since I'm not one of the ones who lost a jet from this manufacturer I can't speak for them. I can only speak for myself and the jet I lost from another factory due to a manufacturing defect.
I wonder if they would have done it without all of the pressure from RCU? JL owners should thank RCU. Jeremy, you now have some solid evidence that a major jet kit manufacturer has offered to replace defective kits that crashed due to their design defects. Let this recall stand as a precedent to all of the other Chinese factories ARF factories who have had manufacturing defects that caused their customers to loose jets. |
ORIGINAL: Rush! ORIGINAL: DelGatoGrande Respect[sm=thumbup.gif] |
ORIGINAL: Frank Sopwith Wow, this is a real milestone! Frank |
ORIGINAL: AndyAndrews Nice to hear them do the right thing. Its refreshing and makes them stand out amongst others who have not. I wonder if they would have done it without all of the pressure from RCU? JL owners should thank RCU. Jeremy, you now have some solid evidence that a major jet kit manufacturer has afforded to replace defective kits that crashed due to their design defects. Let this recall stand as a precedent to all of the other Chinese factories ARF factories who have had manufacturing defects that caused their customers to loose jets. 100% Andy, this is huge. My HOPE for Jet Legend now though, is that people are HONEST. My biggest concern as a company would be that those who are claiming a loss, have legitimately lost the airplane. I like to think that this community is honest in that regard, but it's a big chance that JL is taking, I give them huge props for stepping up! |
IMPRESSIVE! Two thumbs way up for JL.
ORIGINAL: AndyAndrews Nice to hear them do the right thing. Its refreshing and makes them stand out amongst others who have not. I wonder if they would have done it without all of the pressure from RCU? JL owners should thank RCU. |
Wow! [8D]
This is how things should be done..[sm=thumbup.gif]
It's a difficult task to ensure that the claims are honest but hopefully this is were the dealer network comes into play. The jet communities tend to be small and the grapevines short so that should prevent anyone from taking an unfair advantage.
Jeff |
To all the Jet Legend dealers who worked this issue........My hat's off to you. Good job!
ORIGINAL: louisp We apology to the customers who crashed a F20 produced by us; the problem occurred due to our design and not having stressed it enough during testing. We do take responsibility for that. Imagine if all companies did the same what an amazing world would this be. Thumbs up once more and a nice example for more people to follow. Tassos |
Atta boy, Jet Legend.
1 Attachment(s)
Wish I could claim I lost three of them! :D Seriously now, that's how you do business. Jetlegend; up for making a 1/5th scale F-20 or 1/6th scale F-22? If so, please put me on the list, in the meantime, looks like I'll keep the dust off these boxes. ;) Bryce |
[sm=thumbup.gif][sm=thumbup.gif]Very respectable and upstanding![sm=thumbup.gif][sm=thumbup.gif][sm=thumbup.gif]
A huge thanks goes out to Jeff Sewell and Mike Lin for being the front runners for customers and talking to Jet Legend about how to truly serve the customer, my hats off to both of you.
[sm=thumbup.gif][sm=thumbup.gif] |
Wow, I just gained a lot of respect for Jet Legend, to say it was there fault and replace the jets is large, not too many other companies would do that.
Congratulations and respect for Jet Legend Management team. [sm=thumbup.gif]
You show here that all chinese ARF jet companies are certainly not all to put in the "same basket" (french expression) Thanks, Best regards, Sébastien |
Don't forget Monica at CamLex for all the effort she has put into this issue to make it right. Thanks, Monica, for all you and Dante do for us.
Rob Puetz F15driver |
never bought a plane from jetlegend but after this will be top on the list to choose my next one...[sm=thumbs_up.gif]
I also haven't purchased a turbine flyer yet, but this puts Jet Legend at the top of the list for stepping up like they did on this one!
Well done! Jeff |
Hello,
Has the stabilator pivot point been moved forward in the new F-20 kits? And is this an F-20 only or is there a jetlegend F-5? Regards, |
Hi Matt,
The pivot point had been moved forward in the new stabs. There is only F-20 from JL. Mike |
Mike will Global Jet be selling the Jet Legend Jas 39 Grippen?
ORIGINAL: ira d Mike will Global Jet be selling the Jet Legend JAS 39 Gripen? Regards, Jim |
ORIGINAL: rcjets_63 ORIGINAL: ira d Mike will Global Jet be selling the Jet Legend JAS 39 Gripen? Regards, Jim |
ORIGINAL: ira d ORIGINAL: rcjets_63 ORIGINAL: ira d Mike will Global Jet be selling the Jet Legend JAS 39 Gripen? Regards, Jim |
The jet modeling community is appreciative of this admission, unfortunately, if it was not for this forum, the problem would go unrecognized. Let's not forget how this all started. The guy who started this had the same elevvator problem with the JL large f-15 and the design and construction is inferior as is in the f-20. How i know is from the pictures on this forum are identical to the crashed elevator on the F-15 and I am sure the pivot tube is too far aft. I hope JL looks at the f-15 elevator too.
Hi Ira,
We sell JL JAS 39. We have some website photo link errors that would be corrected shortly. Thanks, Mike |
ORIGINAL: mikedenilin Hi Ira, We sell JL JAS 39. We have some website photo link errors that would be corrected shortly. Thanks, Mike Thanks Mike. |
I own a Jet Legend F-18 bought through Mike Lin at Global! Very nice to read this results of a company stepping up to the plate. I will continue to purchase other JL product! Thanks!
Although JL agreed to replace the planes, I still don't trust
these guys. Due to the fact that if it wasn't by the pressure excerted in this forum, they would have done nothing. As other manufacturers. ENT |
ORIGINAL: ira d ORIGINAL: mikedenilin Hi Ira, We sell JL JAS 39. We have some website photo link errors that would be corrected shortly. Thanks, Mike Thanks Mike. [link]http://jetlegend.com/index.php?Page=30[/link] |
