RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Cermark (https://www.rcuniverse.com/forum/rc-jets-120/9810270-cermark.html)
thunderchief 06-17-2010 09:01 PM
Cermark
Does anyone know the recommended throws for the Cermark F-16?
thanks
Glenn
john josey 06-17-2010 09:16 PM
RE: Cermark
I have the ailerons at 15mm each way, elevator 50mm each way and the rudder is 30mm each way. (turbine version)
Roger M 06-18-2010 03:22 AM
RE: Cermark
Mine is similar at elevators 35mm, ailerons 16mm and rudder at 25mm and the CG is set at 155mm from LE of wing.
Roger
thunderchief 06-18-2010 07:16 AM
RE: Cermark
thanks guys,
Glenn
john josey 06-18-2010 07:06 PM
RE: Cermark
ORIGINAL: Roger M
Roger
After thinking about it, your spot on. I use the 50mm on elevator for take off because i have fitted a half litre tank in the space behind the canopy and in front of the turbine hatch that empty`s first, so it allows me to start up, taxi out and get a couple of circuit`s before it starts using the main tanks. I switch to a lower rate after take off which is probably around the 35mm mark.
I also have the CofG at 155mm.
cheers
john
