RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   T10CAP (https://www.rcuniverse.com/forum/rc-jets-120/9850382-t10cap.html)
KAON 07-07-2010 03:00 PM
T10CAP
hi,
i have a Futaba T10CAP and a FEJ 1/8F16 and i am mixed up how to set and program it.
i setup my receiver as follows:-
CH FNC
1 Ail 1
2 Elev 1
3 ECU-Throttle
4 Rudder
5 Gear
6 Ail 1
7 Elev 1
8 Brake
9 ECU-AUX
10 -
So, which mode should i select and how to make the ailerons work as flaps?
KAON
DelGatoGrande 07-07-2010 04:22 PM
RE: T10CAP
read the manual
AirplaneKit 07-08-2010 10:40 PM
RE: T10CAP
i just bought T10CHG, the program is same like T10CAP. use the flaperon mixing function
KAON 07-09-2010 03:39 PM
RE: T10CAP
i did use the flaperon mixing and the ailvator mixing at the same time. but i cant deploy the falps, i assigned CH6 on a switch but when i activate it nothing happens..
BaldEagel 07-09-2010 04:06 PM
RE: T10CAP
Alivator is to use two seperate elevator servo to follow the ailerons, it has nothing to do with flaps, Inhibit the Alivator mix and just use Flapperons and the Airbrake function.
Mike
