Shark Teeth
Anyone have any Good pictures of Sharks teeth on a jet?
I want to put some teeth on my Flash. I did a search and not much came up. I have the vinyl cutter but no good pictures. I tried to draw a set on paper first but my artistic ability isn't all that great :D. If I can get a good picture I can load it into the vinyl cutting program and fix it up from there. |
RE: Shark Teeth
Hi Pete
If you PM me your email address i'll send you a PDF of the one's i did for Ali's eurosport. I digitally printed them, but they are in vectors and could be cut from vinyl. Duncan |
RE: Shark Teeth
1 Attachment(s)
Here's some that Ihad saved. They'll still need to be converted to vector format.
Ken |
RE: Shark Teeth
1 Attachment(s)
this was done with vinyl individual tooth paint masks from pro mark..
RE: Shark Teeth
1 Attachment(s)
RE: Shark Teeth
Shark week!
RE: Shark Teeth
1 Attachment(s)
Sorry PETE but i had to put this image :D:D
João Matos |
RE: Shark Teeth
1 Attachment(s)
ORIGINAL: ddennison this was done with vinyl individual tooth paint masks from pro mark.. Does Henry have talent or what? Paint masks, he don't need no stinkin' paint masks. Regards, Jim |
RE: Shark Teeth
1 Attachment(s)
Hope this helps.
Albert |
RE: Shark Teeth
1 Attachment(s)
ORIGINAL: phjoker Anyone have any Good pictures of Sharks teeth on a jet? I want to put some teeth on my Flash. I did a search and not much came up. I have the vinyl cutter but no good pictures. I tried to draw a set on paper first but my artistic ability isn't all that great :D. If I can get a good picture I can load it into the vinyl cutting program and fix it up from there. I found a photo on airliners.net of a T-45 and I enlarged the tooth pattern on my screen. I then took tracing paper to get the image on hard copy. I then scanned the image and put it into auto cad so I could create a graphic image. after creating the image I printed on decal paper. |
RE: Shark Teeth
1 Attachment(s)
ORIGINAL: RCISFUN Hey Pete I found a photo on airliners.net of a T-45 and I enlarged the tooth pattern on my screen. I then took tracing paper to get the image on hard copy. I then scanned the image and put it into auto cad so I could create a graphic image. after creating the image I printed on decal paper. Way to roll, Rich!! When do you start ballet classes? Jim |
RE: Shark Teeth
Right after he finishes his new Rainbow Warriors F-15...
Beave [sm=lol.gif] ORIGINAL: rcjets_63 Way to roll, Rich!! When do you start ballet classes? Jim |
RE: Shark Teeth
Jim and B.... I can't wait to see you guys again, I'm sure glad your my friends, I would hate to see what you would write if you weren't:D:D:D
Jim is the normal harassment that is afforded to an HC?:D |
RE: Shark Teeth
Thanks for all the ideas and pictures.
Duncan sent me an .eps file that loaded right in. I did some tweaking here and there,printed it on regular paper for measuring and it looks great. I am leaving for a weeks vacation tomorrow morning heading down to North Carolina. So when I get back I will cut it on the vinyl cutter and post some pictures. Thanks for all the input guys. |
RE: Shark Teeth
1 Attachment(s)
Nose of my old Byron's F-20 Tiger'shark'. Future project is turbine conversion on this old bird....
Lance |
RE: Shark Teeth
[link=http://www.military.com/news/article/af-boots-decorated-pilot-for-being-gay.html]Bad news for Rich...[/link]
Beave :D ORIGINAL: bevar Right after he finishes his new Rainbow Warriors F-15... Beave [sm=lol.gif] ORIGINAL: rcjets_63 Way to roll, Rich!! When do you start ballet classes? Jim |
RE: Shark Teeth
ORIGINAL: RCISFUN Jim and B.... I can't wait to see you guys again, I'm sure glad your my friends, I would hate to see what you would write if you weren't:D:D:D Jim is the normal harassment that is afforded to an HC?:D H&K, Jim |
RE: Shark Teeth
1 Attachment(s)
Well back from Vacation. Vinyl is all cut and Sharks teeth are on the Flash.
Duncan, Thank you so much for the file I did some tweaking to it, I made a few changes , I have a vinyl cutter not printer so things had to be changed a little. But I think it came out Great. Thanks again Everyone for all the input and Pictures!!!!! |
RE: Shark Teeth
No worries Pete, glad you like it. Looks like it worked out well on your model to
Duncan |
| All times are GMT -8. The time now is 06:49 AM. |
