Cold Fire: fire extinguishers??
Does anyone know if this product would be safe to use on our jets?? it looks like C02 but not sure. The price is not bad and they would fit easily in a flight box etc.
Thanks, Vin... https://www.mycoldfire.com/flare/nex...FQsCbAodinyJ3A |
RE: Cold Fire: fire extinguishers??
I saw the episode of pitchmen.They said it would put out any kind of fire.
Funny you should ask Vin! I contacted them on Monday for some samples to see if they really work as advertised and to confirm they are safe to use with our engines. I should have some cans here in just a day or two and will run some testing on the Cold Fire....
Will report my findings... Todd |
ORIGINAL: Vincent Does anyone know if this product would be safe to use on our jets?? it looks like C02 but not sure. The price is not bad and they would fit easily in a flight box etc. Thanks, Vin... https://www.mycoldfire.com/flare/nex...FQsCbAodinyJ3A |
ORIGINAL: basimpsn I would bet its CO2. But what ever it is the cost is better than the Home-depo powered stuff[:-]. "The inventor wanted to demonstrate by applying the Cold Fire liquid to his arm and putting a blow torch to it. " That's not CO2... Bob |
Wow cant wait to see this product on the shelf.
http://www.youtube.com/watch?v=9xtCn...eature=related http://www.youtube.com/watch?v=59LcR...eature=related |
it's a plant-based chemical that undergoes an endothermic reaction in the presence of heat. (it separates the fuel from oxygen)
Someone said
applying the Cold Fire liquid That can't be CO2 as it is either gas or solid. It comes out of the nozzle differently. Sounds like great stuff, I can't wait for it to be on sale over here (or is it already?) It looks as effective as BCF, what about environmental impact? |
1 Attachment(s)
MSDS states that it is water soluble and is not recommended for class C (electrical fires).
That would lead me to think that its a much better alternative to powdered ABC types but might still do some damage if shot through a turbine. But anything is better than a blanket or a bucket of sand! Attachment is the MSDS. Mike |
Already for sale at my local hobby shop. Haven't tried it.
Other claims from various sources I've found: it leaves no residue that has to be cleaned up after the fire is extinguished. It has an indefinite shelf life at temperatures between 32º and 150º F. Freeze-thaw does not effect its stability. It is biodegradable If you wish to use Cold Fire as a fire extinguisher at home, you can purchase the solution, purchase a pressurizable tank (a one gallon weed sprayer will work), mix them yourself, and pressurize the tank yourself. That is completely legal and acceptable. 100% soluble in water completely non-toxic, non-corrosive and non-slip. completely non-corrosive and has an indefinite shelf life. You can put it in a 1.5 or 2.5 gallon extinguisher When dry it leaves almost no residue RDR Technologies offers Cold Fire and Cold Fire accessories to the racing industry: 5 gallon pails 55 gallon drums 275 gallon totes 12 oz. spray cans Pre-mixed and winterized formulas 1.5 and 2.5 gallon extinguishers 2 & 4 liter extinguishers Firefreeze Worldwide, Inc. 272 Rt. 46 East .. Rockaway, NJ 07866 973-627-0722 .. fax 973-627-2982 |
When the guy sprays it on his arm, it doesn't look like something that would do a turbine any good...
Bob |
I'd spray the plane if it's on fire but would not shoot it into a running turbine.
Beave |
I remember back in the '80s the fire marshal at the airline I was flying for would drink a glass of Halon 1211 to show us dumb pilots how safe it was during recurrent training.
He's dead now. Beave [X(] ORIGINAL: rhklenke ORIGINAL: basimpsn I would bet its CO2. But what ever it is the cost is better than the Home-depo powered stuff[:-]. ''The inventor wanted to demonstrate by applying the Cold Fire liquid to his arm and putting a blow torch to it. '' That's not CO2... Bob |
I emailed firefreeze and this was their reply:
>>Cold Fire is an EPA approved replacement for Halon 1211 and is non-corrosive, but it is a water-based product, so if your electronics can't get wet (like most electronic things) then I wouldn't recommend it. Doug<< I would say its ok to put out a wet start.There wouldn`t be any exposed electronic circut boards. I know the elec can withstand and kero bath so this stuff should be fine. V.. |
ORIGINAL: bevar I remember back in the '80s the fire marshal at the airline I was flying for would drink a glass of Halon 1211 to show us dumb pilots how safe it was during recurrent training. He's dead now. Beave [X(] |
I'll stick with CO2. I had a club member squirt a Ram 500 with a dry powder extinguisher. Like to never got the crud out of it, yeah its not a powder but it something that will get into the motor, electronics etc.
Well...for $10 a piece...I'd buy 10 of 'em and stash them throughout the house, garage and RV.
Beave |
I think I'll wait for Mikey to try it. For now it's CO2 or Halon.
Roy |
that stuff is a gel. Theres no way in hell I would spray it in my turbine. I'll stick with CO2, but like others have said its cheap enough to stick a can in every room. Cool stuff.
So, if I spray it in my house, does it leave a residue to clean up?
ORIGINAL: gruntled So, if I spray it in my house, does it leave a residue to clean up? |
ORIGINAL: AndyAndrews that stuff is a gel. Theres no way in hell I would spray it in my turbine. I'll stick with CO2, but like others have said its cheap enough to stick a can in every room. Cool stuff. |
ORIGINAL: highhorse ORIGINAL: AndyAndrews that stuff is a gel. Theres no way in hell I would spray it in my turbine. I'll stick with CO2, but like others have said its cheap enough to stick a can in every room. Cool stuff. |
| All times are GMT -8. The time now is 03:51 AM. |
