How to start the Kyosho Mad Force
MD
I tried looking through the arcives but I couldn't find info on ways
to start the Kyosho Mad Force. Can one use a yank eliminator or something?
I am done with pull start. I want to be able to start the mad force electrically and with the body on. Also is there a way to mod the body so you can fill the fuel tank withought taking the body off? thanks!
With the stock engine your stuck with the pull start as far as I know. If you go with the Picco.26 you can use the HPI roto start. Other then that I'm not sure of any other roto start combos. I'm sure they are others. As far as the body goes it really depends on the body you have and how much you want to cut it up you should be able to refuel some how with out removing the body.
