top speed of ek4
top speed of ek4
its only good to do wheelies thats about it!!!!!but there is one exeption here and its the one that rc jack owns that is very unique in its own way nothing like any other ek4's but uses the same engine.....
top speed of ek4
A stock EK4 goes around 33mph I believe. It's best know for it's torque (hence THE .70 ENGINE) not it's top speed. MSJ is working on a 2 spd for the EK4.
God only know how fast it would go with a 2 spd and some taller gears!!
If your gonna get a EK4 (which I did and love it to death!!) then just make sure it's a version 2.
Cheers!
Jeff
Cheers!
Jeff
top speed of ek4
Not quite sure about the difference between version 1 to version 1.5 but from version 1 to version 2 heres some of the upgrades:
* Larger cooling head
* Thru bolts and added webbing on the diff cases
* LSN on carb
* nipple relocated on exhaust
* Gas tank raised
* Carb restrictors
* Starter plate
I might be missing somethings but the bottom line is that the version 2 is MUCH better the the version 1 which I feel is just a beta truck personally.
Go ahead and get a V2..you'll love it!! Just take your time breaking it in (1 gallon plus) and it will reward you with HUGE power!
Good luck!
Jeff
* LSN on carb
* Gas tank raised
* Carb restrictors
* Starter plate
Good luck!
Jeff
