Savage Glow Plug
NY
Savage Glow Plug
The plug that came with the savage blew. All i had was O.S. A3 plugs so i used one of those, is that ok? My savage stopped shifting also, the plug couldnt have caused that rite? Am i loosing power with the A3? If not then what?
AL
Savage Glow Plug
An OS A3 plug is made for aircraft engines. they have a much smaller element and you probably are loosing power. I would suggest the OS A5 plug. it is a great plug for the .21 size engines. it has a large element and is able to hold heat much better. your plug can definatly change performance because it changes the tuning of the motor. you can get the performance back by tuning, but the wrong plug will make the truck more tempermental.
NY
Savage Glow Plug
The truck was shifting when it had the stock plug and when it was rich. When i put the A3 in and started leaning it out a bit it stopped shifting.
I also took the reverse out, so i thought mabey i messed up while taking it out, but when i took the trans apart everything looked fine.
I tried to play with the shift screw but it did nothing.
OH
Savage Glow Plug
The A3 lowered your compression slightly. Probably changed your needle settings a fair amount to. This may have caused your shift problems, or maybe you messed with the shift settings when you took apart? Try a McCoy #8 (MC-8) as well. Little bit colder, may work well, especially if your running 20%+ nitro.
