RC Monster Trucks Discuss rc monster trucks in this forum
Savage SS - Wheelies
Old 09-09-2003, 02:50 PM
Zoned
My Feedback: (14)
Default Savage SS - Wheelies
I have the savage SS with the 15T clutch bell and I still can't pull whhelies. Am I expecting to much or do I have a problem?
Old 09-09-2003, 02:52 PM
badboy2
My Feedback: (13)
badboy2's Avatar
Default RE: Savage SS - Wheelies
depends on where u run it cuz sometimes the tires needs a nice traction in order to pull it..my 8 port does it on asphalt and grass..and my stock bb21 does too on grass but its ported
Old 09-09-2003, 11:22 PM
JAYNC
My Feedback: (7)
How do you have your engine tuned, is it even broke in yet. My savage ss is getting in , possibly in a couple days and I am selling the stock engine and getting an xtm 24.7 pro. I havent seen anything yet that is better for the performance smoothness and most importantly PRICE.
Old 09-10-2003, 07:59 AM
GotSavage?
It might take a gallon or so for the engine to get to peak performance like the 21BB. You could also try to put the 14t clutch bell on and see what happens.
Old 09-11-2003, 08:31 AM
ShOzz
ShOzz's Avatar
how many tanks have you run through it?
i gotthe impression it would be no problem with the .25
my bud has a picco 26 and wheelies on demand.
as far as upgraded engines i have been hearing great things about the wasp 26.
wheelies on demand as well.
Old 09-11-2003, 09:37 AM
nodolarsnosense
Banned
i dont own a MT
but if you really want to do wheelies
get your setup correct so you get traction (bite), or buy better than stock tyres
or the easy way
stick it in reverse first then slam it forwards. the reluctance of the mass of the truck to change direction will cause it to want wheelie itself.
Old 09-11-2003, 10:20 AM
Pkvillager
You should be getting wheelies no problem with the .25. Go to savage-central.com those guys know the savage in and out.
Old 09-11-2003, 11:08 AM
GotSavage?
Have you tried to tune the engine yet? If you are still at factory settings then you probable will not be able to pull a wheelie due to the setting being way too rich.
Old 09-11-2003, 11:52 AM
Kuma
Stiffen those shocks as well.
Old 09-11-2003, 12:45 PM
GotSavage?
If it was a Savage 21 I would totally agree with that but the SS should have the stiffer 6lb springs already. Then again that could still be a bit too soft.
Old 09-11-2003, 03:43 PM
Justintoxicated
that will break your reverse and seize the gears
Old 09-11-2003, 05:40 PM
bubbafien
what is your elevation? i cant pull wheelies because i am super high elevation.
bubbafien
Old 09-11-2003, 07:39 PM
nodolarsnosense
Banned
so howcome you always see it done on all the mt net videos. obviously use you brain about it
Old 09-11-2003, 08:07 PM
grampi
See, if HPI would offer the SS kit with no radio or engine, you wouldn't be stuck with the doggy .25, and you'd already have the money to install that Picco .26 and then it would easily do wheelies!
Old 09-11-2003, 08:30 PM
Avalanche-RCA
ORIGINAL: Pkvillager
Yup, I've got a Force .25 Savage which is just about the same as the S-25 and its an unbelievable wheelie machine. Just be patient and break it in properly. Theses big blocks really arent fully broken in until about a gallon of fuel. I've got a hair over a gllon on mine and its making more and more power every time I drive it. As it sits now it a full stock suspension with one 1/2 inch spacer on one shock in each corner, a 3 shoe mugen clutch and the stock 14 tooth bell, and I cant keep the front end down, I actually have to tune it a bit rich to keep it managable. Its also got a hotbodies pipe and a motorsavers air filter.
Old 09-12-2003, 07:27 AM
Legendary
Avalanche is right! I takes a long long time to get this engine broke-in! I also have the Force .25 (which as stated is just about the same thing as HPI's seeing how Ofna makes it) and there was a big big difference in the power once it finally started to break-in! It went from being kind of slow (enough for me to take it off and put one of my other engines on it) but, when I read that it can take much longer then most engines to break-in I put it back on and it was worth it!!! I finished the break-in! Now it wheelies all the time,idles and runs great! Take your time it is a great engine once it is broke-in!
Old 09-12-2003, 07:54 AM
caseyddr
My Feedback: (13)
caseyddr's Avatar
is it jus me or are alot of the new ppl around here rather... uh.. unintelligent? I'm scared its going to rub off on me if it hasnt already....[:-]
Old 09-12-2003, 09:29 AM
Smokinjoe6450
Its just you........now run along and get back on the short bus to school with all of your special friends.
Old 09-12-2003, 12:34 PM
Aterlatus
Yeah, you can sit next to me... [:-]
I guess this's what happens when you stare at a computer screen all day [&:]
Old 09-12-2003, 01:01 PM
Rex2342
Rex2342's Avatar
I have a question thats a little off topic but its still about the Savage SS.My freind is buying one soon and hes going to let me to build it(I begged him).Anyway were the diffs already put together in the Savage SS?I'm going to add some parts to the SS to make it better while I'm building it and was just wondering if I am going to have to take the diffs apart.
Old 09-12-2003, 01:11 PM
ZipZap
The gearbox and both diff's come assembled.
They're easy to get apart. Mine are sitting disassembled right now while I wait for the parts to upgrade to 4 spiders. Took less than 30 minutes to get both totally disassembled and cleaned.
Parts are on the fedex truck today!
Old 09-12-2003, 01:18 PM
Rex2342
Rex2342's Avatar
I have a Savage21 already with the 4 gear diff mod.I was just wondering if I had to tear the diff apart to do it to my freinds SS when he gets it.Looks like i'm going to have to take the tranny apart too just to make sure those little retainer screws are tight.Shouldn't take long to put together though.I've torn mine down to the diffs and put it back together in 6 hours so this should be pretty easy plus I don't have to clean it LOL!!!
Old 09-12-2003, 01:35 PM
ZipZap
The cleaning part is removing the existing grease from the diffs. Nitro cleaner makes it pretty easy.
Old 09-12-2003, 01:51 PM
Rex2342
Rex2342's Avatar
Yeah I'm going to replace the grease with silicone oil.1000wt rear 3000wt front
Old 09-12-2003, 02:12 PM
ZIZI
the reason your savage isnt popping wheelies is because of its massive shocks
All you have to do is tighten up the rear shocks and it will be poping wheelies all over the place!
ZIZI
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
