how do you take this off
I'm trying to check my clutch and I can't take that screw out that holds the clutch bell and all on the engine shaft. What do you have to do. It just spins, no matter what I hold.
RE: How do you take this off
You can ethier use a piston stop to hold the motor from turning or if you are VERY carfull you can use some pliers to hold the fly wheel....just put a rag in the jaws of the pliers to protect the flywheel. Be carfull doing it this way!
