cen gst 7.7
cen gst 7.7
Hey looking for information on my monster truck as why it dosnt move when on the ground just sits there and revs up but when have it off the ground the wheels spin but can stop them with ya hand is this something i can fix by adjustment any info will be much appreicated thank
Ts slipper clutch can be adjusted, have a read of your manual (CEN should have an online version) for more details on that. The clutch on the engine can be adjusted, but this is done with different strength springs. If the clutch on the engine is bad you'll likely see blueing on the clutchbell indicating excessive heat. Check for this and remove the clutch (pull the engine) before ordering parts though.
