RC Monster Trucks Discuss rc monster trucks in this forum
hi need stearing help
Old 02-18-2016, 09:07 PM
Default hi need stearing help
hi redcat people.. i am a fan of the red cat and i need some help. i want some help with the stearing. i own a blackout xte pro and the stearing is pretty ruff. i found the problem is undersized spacer that needs to be replaced with a bearing. i just want to know where i can find the bearing to fit it. image attached. it's wobbly.
Old 02-18-2016, 09:50 PM
Maj_Overdrive's Avatar
If you look in the manual (the manual is your friend and available online too!) you'll see the part number for that bushing is BS903-122 and its size is 5.1x8x2.5mm. So you need a bearing that's 5.1mm inner diameter X 8mm outer diameter X 2.5mm thick. You're not going to find a bearing with a 5.1mm diameter though so get 5mm. It might be a tight fit but you could always rub the shaft it goes onto with some fine sandpaper to take it down a little.
Old 02-19-2016, 04:08 AM
wonderful thanks
http://www.amazon.com/gp/product/B01...ilpage_o00_s00
got the last one. thanks broski. sure glad I came to these forums.
I'm thinking that .1 is the reason it's loose.
Old 03-12-2016, 05:29 PM
I just replaced these on my Earthquake 3.5, with Traxxas 5x8x2.5 bearings. The fit is SO much better, and in turn, the steering is so much smoother.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
