Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Monster Trucks
New to RC, bought a BL ECX Ruckus with some problems. Need help. >
RC Monster Trucks Discuss rc monster trucks in this forum
Old 12-15-2016, 04:56 PM
Default New to RC, bought a BL ECX Ruckus with some problems. Need help.
Hello all,
I'm new to hobby grade RC. I've been reading up on it for over two weeks and yesterday I won a brushless 2wd ECX Ruckus on eBay for $140. It has a few issues.
First it has a broken axle/driveshaft. I figured I'll just upgrade them instead of putting stock ones back on. I looked into it and it seems like the hot racing star drives are the best ones I can get. Anyone have any experience with them?
Second is that it doesn't come with a battery. I know it can run a 2s lipo but should I just get a 3s or will that overheat it? It already has a fan on the ESC. Also what c rating should I go for and about how much runtime time should I expect out of a 4000mah battery?
Also since it's made to run on a lipo should I get an LVA or will I be fine with the stock system? Can someone point me in the right direction for a decent LVA?
Thanks in advance!
Old 12-16-2016, 03:16 PM
Do you know what ESC it has ?
This will determine what voltage it can handle !!!
Old 12-16-2016, 04:47 PM
Should have also asked what KV the motor is ? This this will also have a bearing on what voltage is reasonable .
Old 12-17-2016, 01:25 AM
It's the stock brushless motor and ESC. Sorry about that. Motor is 3300kv and ESC is 45A sensorless with Active Vehicle Control.
Old 12-18-2016, 09:13 PM
45 Amp is on the a bit on the low side for a 1/10 scale in my opinion .The esc and motor will handle 3S according to the specs , but I would be careful how you drive it . As an example , too many attempts at long wheels on a grippy surface will get it hot ! Loose surfaces won't be as bad as they put less strain on the motor .
Old 12-18-2016, 10:11 PM
I will mostly be driving it on dirt and fine loose gravel. The ESC already has a fan on it but do you have any suggestions on an upgraded one? What c rating should I get for the lipo?
Old 12-18-2016, 11:20 PM
I would go for a minimum of 30C on any Lipo you get , some people like more .
Old 12-19-2016, 12:49 AM
I would not bother to upgrade unless something goes wrong with it . Something like a Hobbywing 10BL60 + program card would do the job .
Old 12-22-2016, 09:08 PM
Awesome thanks so much for the replies!!
Old 01-13-2017, 12:45 PM
Doesnt the fan needs to be changed from 5v to 12v? Just asking...
Where you able to find any upgrade parts for the dog bones?
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
