HELP!! newbie break in questions
IL
I just started to break in my savage rtr .25 when I start it up it starts out fine. but then with in about 1min. it starts just go's wot I adjusted the throttle adjustments on my (stock)transmitter but it does nothing to help I end up having to use the break so it doesn't fly off the box that I'm using for a stand. please help me
RE: HELP!! newbie break in questions
You dont need to mess with anything yet until you get it broken in. Just follow the instructions. You can put after run oil in before but it wont really do much. Follow the instructions and you will be perfectly fine.
No thats not normal...what are you doing with it right now? Are you running an idle tank or what step of the break in are you on? Also did you touch and needles or the idle screw or anything?
IL
I was running an idle tank But now their are even more problems my roto start is smoking and smells like crap not to mention the roto start button is stuck in the on position. only way i could get it out of the car was to pull battery out of it remember this is only 2 hours old roto start and car. at the moment I'm just goig to send it to hpi for them to deal with hopfully unless someone can help me fix it or tell me how to fix it.
I don't want to turn into a savage basher but with this crap I may soon be.
