ss or .25
RE: ss or .25
they are not the same trucks......they are almost the same truck.
the ss comes with a different tuned pipe and i think it still has the old fuel tank. the 25rtr comes with the plastic pipe and has a new fuel tank. and i think there was something else....but i forgot
RE: ss or .25
the 25 comes with roto start and a 3 shoe clutch, the SS comes with upgraded dog bones and a pipe and pull start.
you build the SS, the 25 you just tale the engine out locktite the backplate then put it back in.
the tank on the SS works with no problems.
big deciding factors really come down to , do you want to build it?
do you want a pull stat or a roto start ?
RE: ss or .25
See this chart for an easy comparison of the Savage 25 to the Savage 21 and Savage SS!
RTR Savage 21 RTR Savage 25/ Savage SS
Engine-- 21BB Nitro Star S-25/ Nitro Star S-25
Tuned Pipe--/ composite/ composite/ Polished Aluminum, Ribbed
Starting System-- Manual Pullstart/ Roto Start System / Manual Pullstart
Spur Gear-- 52T/ 49T / 49T
Clutch Bell-- 14T 15T / or 18T 15T/ or 18T
Clutch Type-- Two Shoe/ Three Shoe / Two Shoe
Shock Springs-- Red Medium/ Black Firm / Purple Firm
Fuel Tank-- with primer, front pick-up/ without primer, rear pick-up /with primer, front pick-up
Body-- Black-Silver-Purple Red-Black-Silver-Gray supplied clear
Dogbones-- updated standard /updated standard /Heavy Duty Silver (#86134)
21BB / Nitro Star S-25
Size-- .21 .25
Horsepower-- @ RPM 2.3hp @ 30,000/ 2.5 @ 29,000
Maximum RPM-- 38,000
Heatsink Head-- cast metal /Machined Aluminum
Case-- silver/ Black Heatsink Coating
Carburetor-- metal /Composite
Carb Adjustments --High, Mid, Low simplified to High and Low
Connecting Rod-- single bushing /Dual Bushing
Construction-- ABC /ABC
its kinda hard to read... you'll figure it out
Size-- .21 .25
