please HELP!
RE: please HELP!
how new is the vehicle? if its brand new, u most likely need to adjust the slipper clutch. if its old, check the diffs and the clutch for wear. check the clutch first, then the diffs.
RE: please HELP!
if the engine revs but the clutchbell doesnt, then its in the clutch. pull off the clutch and inspect for wear. most likely either the shoes have worn so badly that there isnt sufficiant contact patch remaining, or they are so glazed, they are excessivly slipping
RE: please HELP!
ok im lookin at it. Its like 3 peices with a spring around them and it just rubs up against the clutch bell. And bothe the cluth peices and the inside of the bell are smoothe so idk what is supposed to stin the clutch bell at all.
RE: please HELP!
you will have to type a bit more legible. i cannot understand what you are asking.
take everything apart, and sand the shoes and inside of the clutch bell with fine sandpaper. then clean it thoroughly with DA or nitrocleaner. reassemble everything and test it out. if it still doesnt work, lemmi know.
RE: please HELP!
If you are not sure what your shoes are supposed to look like, go to your LHS or get on tower hobbies and find a pic of your shoes. If they look significantly different than the pics or what your LHS has then replace them. If they are worn to points on the end with no hole, replace them. If they look like they are still in good shape, then sand em and clean the bell. Last of all, make sure they are the right shoes. I found out this weekend that traxxas shoes will not work in my Cen, they are to light and the spring is to heavy. So if your spring is the wrong size or your shoes to light, it wont engage the clutch bell.
GA
RE: please HELP!
hey i responded to the nj thread but yeah my brother is kyle...i will be coming home for thanksgiving next week sumtime and plan on bringing my t4 home with me if your truck is still giving you problems i could prolly take a look at it and see if i can get it fixed
