SAVAGE TIRES? ? ? ? ? ? ?
i recently bought 4 Savage wheels and tires for my E MAXX and they are very soft.They are already glued.Will they still work ?Can i put some glue remover on them and add foam or will it not be worth it.Is foam the only way to go?I'm on a limited budget so new ones are out right now.Thanks
RE: SAVAGE TIRES? ? ? ? ? ? ?
stock savage tires have very soft foam in them and the side walls will roll over on turns. however the tires are very good they just need better incerts. i used trinity blue foams, the part# is TK5113. go to tower hobbies and punch in the part # they should be under 20$ or you can find them at your lhs.
