drill 2.5 pipe?Performance
has any one made there stock pipe outlet bigger, instead of buying a sirio big bore pipe? by the way i'v got a fridge head and i'm lacking heat and power
RE: drill 2.5 pipe?Performance
Well Pipes are not made to be drimmiled.
If they were ment to they wouldnt sell the big bore pipe.
DO NOT DREMEL YOUR CURRENT PIPE!
It can severely damage your exast system!
MD
You can take the stock T-MAXX muffler apart by taking it off and unscrewing the long screw in the center and remove the plastic cone inside and get the same results as spending $50.00 on an aftermarket pipe all it takes is ten minutes.
