need help wit hpi nitro mt
BC, CANADA
RE: need help wit hpi nitro mt
Powerline and Megatech makes great parts for it, there's a list of Powerline parts at Tower Hobbies. If you want to go all aluminum you can get:
4mm chassis or 2.5mm chasis, gearbox, center gear brace, upper deck, front & rear arms, uprights, knuckles, shock towers, steering bellcrank & slider. And also titanium turnbuckes from Lunsford.
There are also alot of other parts found on ebay such as metal spur gear, fibreglass upper deck, slipper clutch and a 2-speed transmission. Parts from the new Nitro MT2 are supposadly improved so you can upgrade the chassis and suspension system.
So far I've gotten Ofna MBX front & rear shocks and throttle/brake levers also from an Ofna MBX for a slide carb setup. There are tons of possibilities and I'm having fun finding out what other things fits, I'm still looking for a bigger fuel tank that'll fit.
