shim diffs?? xtm mammoth
RE: shim diffs?? xtm mammoth
With time, your diff gears will start to wear and the teeth will get smaller. This results in less gear mesh which can make them skip or even break. Shimming a diff involves adding small metal washers behind the gears to push them closer together, increasing gear mesh.
