It's ALIVE, big, bad, and green... "The Hulkster"
After a long break from “The Hulkster”, I finally decided to complete what I had started. First, I had to fabricate a front bumper/servo mount. It is made from 1/8” aluminum with ¼” dia. Aluminum rod. I finished it off with a couple of coats of “Grabber Green” paint for good looks.
For the rear I used an aluminum bumper that wasn’t being used, and after some paint it fits right in.
That just left me with wiring up the Super Rooster to the Speed Gem Sapphires, and setting up the steering servo. Here are some poser pics of the completed truck I took at work today.
Now I just need to see if I have the brass to run it on the rocks??? If not, I may have to part with it, because I can’t seem to enjoy a “Shelf Queen”… Only time will tell….
Martin
Martin
ON, CANADA
RE: It's ALIVE, big, bad, and green... "The Hulkster"
Damn!
That is one nice clod
Nick
could you go into more detail on what you fabricated to I may do the same when i get my clod
I like your color choices and the body is the best who makes it?
Nick
The frame is a Zilla 4 which has been powder coated green. I can't recall who painted the body. I painted the gearboxes purple and all the hardware for them green. I even stripped the motor cans and painted them to match. I did the fab work on the front bumper, and narrowed all 4 wheels.
Martin
Martin
ORIGINAL: Smokinjoe6450
Nice truck....is there a reason your tires are on backwards?
Better traction when crawling...
Still looking nice (and green)...
Crawling is a blast with the right set-up.. I have 3 crawlers running at the moment, and 2 more under construction..
Martin
Martin
yea, cool truck looks like you put a lotta time and effort into it,
well it payed off[8D]
