xtm in a mad force
xtm in a mad force
is it at all possible to put the xtm .24/7 in the mad force. even better can u fit a .25 or 26. into the mad. please tell me cause wit a more powerful motor it will be insane. post some pics of ur mad force also for any advise go to madforce.net
YT, BOTSWANA
RE: xtm in a mad force
Yes, you can put a 24.7 in there. As long as the motor mounts in the space a .21 would, then you can run it. In a mad force, its gonna be nuts.
Matt
Matt
which motor mounts the xtm or the special mad force ones. also were can i get one. and what manifold/ tune pipe do u recommend. did u try and do u have a mad force if u do post a pic or vid.
Double check on this but. The R.C. limited engine mounts will allow you to mount any .21 to .26 engine. The other ones don't always work with any engine. As far a pipe and engine I'm running a 8p hyper in mine with a .069 Ofna one piece low end pipe.
I would suggest you to get the OS21RG-X(P) its insane in the mad force and easy to break in and tune.
Here are some pics of my mad force with the OS21RG-X(P)
there's a guy on madforce.net that has a 247 in his. as fast as my pro version makes my savage, i can imagine what it'll do to a mad force, with the three speed. if you want the pro version, look for engine_nut on e-bay. he sells them for $155 shipped. the mach 26 (lst stock engine) is another choice, and they go for about $130. basically the same thing. i have the hpi ribbed pipe on my 247 pro, and it's great. VERY loud though. might not want an hpi part on your kyosho though.
also im thinkin about when i get it to buy some t-maxx/ savage hex adapter and take those gay wheels and tires and replace them wit pro lines white dish 40 series wheels and 40 series bow tie tires. then take the dule shock adapter and use the pro line shocks. then get the t-maxx/savage crowd pleaser body
check them out at www.prolineracing.com
