Revo gets an Rx
YT, BOTSWANA
Revo gets an Rx
I figured now was a good time to set the Revo up for the track. It gets too busy in that track to share frequency clips, so i went synth. Check out the size difference. I'll be buying the Hitec Aggressor CRX synth soon, and all hitec servos. I just wanna try something different this time around.
YT, BOTSWANA
RE: Revo gets an Rx
Its a frequency synthesizer. Now when i go to the track, i can run any available 75 FM frequency without buying all the crystals. I can just adjust the RX, and the TX.
ORIGINAL: oatmealman
cool what exactly does a sytnh do,not really into goin to the track i mostly bash in school parking lot driving over peeps car
YT, BOTSWANA
RE: Revo gets an Rx
ORIGINAL: Mxracer45
Those stock tires thermal?
RE: Revo gets an Rx
For one thing the Novak and Hitec synthesized receivers are both fully compatible with the JRXS3 radio system. The direct JR receiver is the RS300 or the newer even smaller RS310 which I suggest you check out thermal. Very small.
YT, BOTSWANA
RE: Revo gets an Rx
Because this truck is not gonna use the JR radio forever. I'll be buying the Aggressor CRX synth radio, that comes with the Novak module.
ORIGINAL: breakin2
Why wouldn't you just buy a JR receiver to use with the synth radio that came with the LST?
CA
RE: Revo gets an Rx
I have no problems with frequency conflicts at my track, but there was only 8 MTs racing yesterday. Another thing is I jacked green from my E-Maxx, so the only other person I know using green at the track is a guy with a Rustler.
YT, BOTSWANA
RE: Revo gets an Rx
During the week i would be fine without the synth. I go on a sunday, or during the busy fall, and winter season, and im in trouble. I dont like to be the guy waiting on frequency clips. I see from your sig you installed the close ratio trans gears. How do you like it? Did it change both first, and second gear ratios? Or did it just bring 2nd closer to first?
ORIGINAL: S7 Europa
