TNX or LST?or MAMMOTH?
MI
RE: TNX or LST?or MAMMOTH?
They all have small issues....
The TNX probably has the least issues, but its also not as popular as the Mammoth or LST and parts availability may be low.
I have the LST, yes it has some small issues but its still an awsome MT. The truck was designed for the track. All you need to do is get rid of those oversized tires and put on a set of HPI Dirt Bonz and off you go. The radio system is perfect. I bought a few synthesized receivers to put in my other MT. Now, I can control several of my MT's with the same transmitter that came with my LST and have eash setting saved. You really can't compare the the LST with Mammoth because technically the Mammoth is a "Truggy" thats right it is. The TNX is awsome track MT. I have seen them on the track and they are excellent. The TNX is has a smallblock MT with a 1/8 body. It does not have the torque of a big block MT but its lightweight does make up for it. For the money you can't go wrong with the TNX all you will need to do is replace the radio system and change the tires. The LST has insane power. The torque and aceleration of LST is incredible. The suspension is very stiff a little too stiff for a track that has a lot of small bumps. Soft spring as of now are not available.
MI
ORIGINAL: tamiyakid08
tnx!!! had no problems
MI
The RB .28 is all about torque and down low power. Very smooth powerband and pulls strong from low to mid, but it does die off in the upper RPM's, but really it is a bashing MT engine according to RB products, they do plan to offer an 8 port race version later on.
Hindsight (should bought the WS7II since my goal is racing).
