Which bodies will fit the Mammoth??
OH
I need a new body but the only body i found was 30 bucks and it was the original, unpainted body. is there anymore bodies that will fir the MAMMOTH, IT DOESMATTER IF IT IS UNCUT AND UNPAINTED, JUST AS LONG AS IT FITS!! GTHANKS
OH
RE: Which bodies will fit the Mammoth??
Mabye, but the Mammoth is 23 inches long so how can they fit. Also, does the link i posted above bolt directly on the Mammmoth because i am preeety sure that body has pre cut holes. If i am wrong, then please correct me. And please give me some more bodies that you are SURE will fit the Mammoth. Thanks!
YT, BOTSWANA
Then it would have this spur gear guard...
Then the new black chassis...
Then the new XTM racing wheels and tires i put on my LST.
MI
LOL I don't have the money to keep up with what ThermalRD wants! XTM parts are expensive compared to some of the bigger name guys.
I do need a new body...the stock is barely holding on. Spur Guard is not important the stock one is stick fine so far. Black chassis is pimp and strong...but $99 is woohoo outta my league currently.
Do love those new XTM Large series wheels and tires though...
WA
Try these bodys out.
[link=http://www.carttonic.com/catalog/index.php?file=catalog&action=catalog_productinfo&uid=466&pi_id=12124&clist=0,11276,12001]Extended Cadillacl Escalade Body [/link]
[link=http://www.carttonic.com/catalog/index.php?file=catalog&action=catalog_productinfo&uid=466&pi_id=12122&clist=0,11276,12001]2000 F-350 Super Duty Truck Body [/link]
ORIGINAL: ThermalRD
hey where did you get those new xtm wheels and tires? I cant find any info on them ANYWHERE
i want some for my mammoth
MI
The wheels and tires are called the XTM Large Series.
Linked here: http://www.hobbypeople.net/guru/kws_57245328.asp
You will need the XTM Mammoth 14mm Adapters for the fronts and rears to make those wheels work. You'll need the (146110) for the rear and the (146112) for the fronts.
OH
aj dragon, those bodies are for tmaxxes and they say theat they are too short. casn someone else pleas epost an mgt opr something that will fir the mammoth because i cant seem to finbd one
MI
ORIGINAL: MT RC
Crowd Pleazer 2.0 Racing Body
Ford 2004 F150
Ford F350 Extended for long trucks
Hummer H2 SUT
Clear MGT Body
Blue Painted MGT Body
Red Painted MGT Body
TX
the bodys from proline are also thicker then most other bodys out right now, they can really take a beating.
hey thermal where did you find the wheels (rims) at, those are pretty tight.
any body that is an extended body will work. Where can I find that stock body but the blue and white one???? EMail me @ [email protected] thanks
