your dream truck
your dream truck
if you could go up to your favorite manufacturer, and have them build a custom monster truck just for you, what features would it have? how many speed tranny? what engine?, tires? shocks? tvp or flat chassis? what new and innovative features would it bring to the table? remember DREAM! (but keep it realistic.)
My Feedback: (-1)
RE: your dream truck
Savage with
lightweight 3 shoe flywheel
carbon fiber tvps
motorsavor airfilter
dodge ram body with working ram hood
3 speed tranny
Fantom 27 ( done up by ebmods)
Hpi dirt bonz
hpi q6 rims
throttle mod
steering mod
powerful steering servo
stock savage 25 shocks
powerful throttle servo
Working super charger
lightweight tranny gears
lightweight engine case
ribbed purple pipe
adjustable upper arm
4 spyder diff mod
mip cvds
a nice quality controller that tells you the weather temp and what temp is best for the engine in that weather
thats my Dream truck
carbon fiber tvps
3 speed tranny
Hpi dirt bonz
hpi q6 rims
throttle mod
steering mod
ribbed purple pipe
4 spyder diff mod
mip cvds
Since a savage would NEVER meet ANY of my performance features: Kyosho Mad Force or XTM X-Factor.
Mad Force:
OS .21 VZ engine
Motor Saver filter
Hub conversion for Tmaxx/emaxx wheels and tires
Tmaxx wheels (i could care less)
Proline Tmaxx tires (doesnt matter what kind)
Wow look at my list to make the Mad Force a dream truck, way shorter than a dream savage or even a Tmaxx. Note how the MadForce is also more durable... woot.
Mad Force:
OS .21 VZ engine
Motor Saver filter
WA
Hi
You did say new and innovative features didn’t you. Well I would start with a Savage and this is what I would want built in to it.
01. 3/8†thick 7075-T6 aluminum TVP with a 1 ½†extension
02. 3 speed tranny with the gears to the 3 speed made from solid Delrin
03. CVD’s front, rear, and center
04. 250cc fuel tank
05. Pro-Line Moab 40 series Tires
06. The 4 bevel gear diff kit front and rear
07. Trinity S27-R Sirio .27 Racer Monster engine
08. 3m.m. ***. Front, rear, and center skid plates
09. Aluminum Tranny case
10. Steal disk brake with semi metallic brake pads
11. Delrin spur gear
12. External Fuel filter
13. Aluminum servo saver steering bellcrank kit
14. ***. Turnbuckles, and hinge pins
15. Airtronics 94359Z Hi-Torque Servo (200 oz-in, 0.1s, BB, Metal Gear, Heat Sink Case)
16. JR XS3 3-Channel Synthesized 75Mhz Computer Radio System w/2 Servos
17. Mambo 40 Series Wheels
18. Reverse module
This is all I can think of for now.
04. 250cc fuel tank
18. Reverse module
TX
ORIGINAL: AJ DRAGON
Hi
04. 250cc fuel tank
18. Reverse module
Hi
04. 250cc fuel tank
18. Reverse module
well i have two of them
one: a t-maxx that doesn't break . . . at all . . . lol lol and that comes with a .28 right in it
two: ok well u take tvp and insted of them arching they will be straight to lower the center of gravity the u put in three diffs with a super low gearing truggy like and lock the center and put torsen diffs in the front and the rear. engine would be either an rb or an sirio .28 monster. for shocks there are a couple choises one; lst shock mod or two; pro -line shocks that r long and r made for the savage. super thick plastic lower a-arms and either aluminum upper or graphic upper all around. there would be no transmission case because of the center diff and no radio box all the the electrontics would be mounted to the tvp's. over all the truck would be 8.9 pounds and have 3.5 hp and have a top speed of 48mph. it will have all that power but it will be all acceleration so it will be a monster on the track. the best thing about it it would be made by hpi.
Well mine is not really a dream as I am working on getting it soon.
Revo with the following:
Hardcore Racing Titanium Undercarriage
Team Orion Wasp .28
MIP Front/Rear Shiny CVD
Lunsford Racing Titanium Turnbuckles
Lunsford Racing Titanium Pivot Balls
Lunsford Racing Titanium Hinge Pin Kit
And then go from there.
Team Orion Wasp .28
My Feedback: (-1)
ORIGINAL: rccars411
Mad Force:
OS .21 VZ engine
Motor Saver filter
Mad Force:
OS .21 VZ engine
Motor Saver filter
MN
Nuclear fusion powered truck. Am i too ahead of my time or what???
Or turbine powered! You ever heard those turbine powered RC helis!!? TALK ABOUT COOL! When they bring down the head speed, it sounds like a jet engine being turned off. So cool.
My Feedback: (9)
IN
ORIGINAL: rccars411
Mad Force:
OS .21 VZ engine
Motor Saver filter
Mad Force:
OS .21 VZ engine
Motor Saver filter
My Feedback: (-1)
ORIGINAL: camra88
I'm sure it would be fast if you had one for each wheel
My Feedback: (10)
some many things people do with the little turbines, i have seen them on bikes, skate boards, and cars
http://www.corpcomp.com/weeks1/car/car.html
My Feedback: (-1)
ORIGINAL: oatmealman
downloaded the vid [X(],screw my .16 i'm putting a 42lbs of thrust turbine in my truck it would fly,problem is no torque[:'(]
