Trinity Spyder in stock tommorow!!
YT, BOTSWANA
RE: Trinity Spyder in stock tommorow!!
Cool...Be sure to post size comparison shots next to the most popular trucks(revo, savage, LST, etc.). Whats that beast gonna sell for?
NJ
It does not really have any ground breaking features. It just improves an all features we have seen before. All aluminum shock bodies and caps, bigger .27 Sirio engine, metal gears,1/7th scale,Tuned “427 Monster Horsepower™†engine, 4.27cc, .256ci
Tuned exhaust system , Oversized fuel tank for longer run times 8 shock fully independent front and rear suspension engineered for maxi-mum travel and cornering speeds 2 Speed transmission with reverse ,Adjustable shift point to track tune your horsepower
Metal gears in transmissions handle tons of power easily
Dual plate design makes a super stiff and strong chassis
Oversized wheel hubs keep rims from stripping
Hi-torque servos etc...
is it just me or does that gas tank look like it'll have issues with fuel sloshing around? Espescially when it gets low on fuel.
My Feedback: (10)
yea, when i first saw it i was like, i gotta get it, then i saw the price 799.99 at tower when it first came out. now its like as much as a revo. sweet, might pick up one. revo is sweet, but every one has one.
My Feedback: (10)
survey:
Think its gonna have problems like the lst; put down a 1
think its gonna be sucessful, put down a 2
you gonna buy it: 3
think its a POS: 4
so your reply should be like this
i think, 1,2,3
meaning you chose those. say as many as you want
you gonna buy it: 3
think its a POS: 4
i think, 1,2,3
break that ***** in....take some videos, post em up! I am wondering how it runs/handles/performs. also if you have another truck you can set it next to.....id like to see the 1/7 scale difference next to a revo or savage or lst if you know anyone whos got 1
looks so good clean man .....get it dirty
YT, BOTSWANA
Nice pics! Do us a favor though. The specs say OVERSIZE wheel hubs. Could you define oversize? If they arent 14, then what size are they? Maybe a 17 mm?? If you plan on running it, take note of the steering radius for me. Id like to know how tight it will turn. It looks good though. Real good. I dig the name and graphics on the body too.
MI
ORIGINAL: ThermalRD
NJ
everything looks very well built. i like how batts and rx is accesable by just removing clips! . tank also removes by clips. tranny looks like it can be removed with only 4 screws!very clever trinity. i would have to say that so far this looks to be the best designed monster truck so far. 2nd would be mgt. Ill know more after drive.
MI
LOL It's kinda small...my Mammoth is much longer than a REVO, yet this Spyder looks more like just slightly bigger than your Revo.
yet another truck that uses many design cues from the savage, there seems to be a rook of them at the moment, looks good though
YT, BOTSWANA
Ummm...Ok, well that pretty much sucks. Thanks for the info though BT. Who else makes MT wheels in 19 mm?? If they were 17 you could use dominator wheels right?
ORIGINAL: binaryterror
RC Car Action says 19mm...and those wheels and tires are straight from the DuraTrax Dirt Demon...no change and those were 19mm too.
ORIGINAL: ThermalRD
My Feedback: (10)
not many companys make 19mm. ofna, is all i found (pics) i would convert it to use 17mm or prolines 23mm thing
23mm proline
yes dominator wheels are 17mm.
bt: did you call it a duratrax dirt demon???
i must say that engine head is way too small.
19mm from ofna
23mm proline
19mm from ofna
ORIGINAL: ThermalRD
ORIGINAL: ThermalRD
MI
Wanna guess...just Cen and their Genesis! I do know Kyosho used 19mm on the Inferno 6 or so and I think you might be able to use the 17mm hexes like I do...I'll show you Sunday.
ORIGINAL: ThermalRD
NJ
Just Ran the 1st tank of gas. She started right up and never quit running on the 1st tank. What an engine! This sirio is very easy to start. Brakes are very strong and will flip truck on its lid if you brake too hard. Steering servos is weaker than expected but good for a stocker. I was running a 5 cell battery. It could have needed a charge . Ill post more on sunday. Steering radius is tighter than MGT, Losi LST. Engine is still running rich , but you can feel the power. I think this is one of the best stock egines in a RTR truck ive seen. Head on engine can be improved vastly with a larger machined head. Should lower temps by 15- 20 degrees minimum. This will be the 1st upgrade...
see pictures on my website....
http://www.parkflyers.com/html/spyder.html
NJ
Ran 2nd Tank of gas. Be carefull with brakes . Brakes are so strong i flipper her on its lid and scratched head a bit. No biggie , gotta dial out some brake. Was starting to run too rich as rengine was breaking in. Leaned her out 1/8 th turn to keep her running. Brakes seem to get stronger with use. (like a real car) Car tracks tru and straight and is very planted and solid feel to it.
Welcome to my new fav truck.
PS ...What an engine i can feel the power at only 1/4 throttle.
Will Post more sunday
YT, BOTSWANA
Did i read that right? You claim that truck steers tighter than an LST? I'd have to see that in person to believe it. I also noticed you keep referring to that engine as a Sirio? Why is that? There is no way that engine is of the same caliber as the Sirio .27 line of engines. Any video?
