Same Sized Bodies
Same Sized Bodies
hi. i was just wondering if MGT, TNX, TXT-1, and LST bodies had the same sized bodies/ same mounting hole positioning as the savage/revo/t-maxx...
also, are they all compatible with the same rims/tires (except for txt-1... i know you need adapters)?
thanks
thanks
YT, BOTSWANA
RE: Same Sized Bodies
MGT, TNX, and LST all use 14mm wheel hexes. The bodies for all 3 trucks are considered 8th scale, so any of the larger proline bodies will fit those trucks. Parma makes a few larger bodies too.
