Servo noise poor perfomance, Help?
AZ
Hi! I just received my MGT (used) and the steering servo makes a noise when I turn on the battery switch.
Batteries are new, but the wheels are moving very slow.
Are this signals of a bad servo or is something that I can change to fix it (better batteries, etc).
The seller told me that there was no problems with the truck at all just a cracked front bumper.
The engine started with no problems but was very slow (but that I think is my servo setting and the motor needs to be carburated).
As you see, I'm new to the hobby. Thaks all for your help!
AZ
RE: Servo noise poor perfomance, Help?
It is the stock one for the MGT
Attaching a picture but dosen't show any thing
Here is the link with more pics: http://cgi.ebay.com/ws/eBayISAPI.dll...e=STRK:MEWA:IT
In the case of a bad servo, tell me a good brand to replace it
AZ
Thanks for that! Batteries are new, but I will try some good rechargeable ones.
I couden't find if the stock servos for the MGT are digital or analog. The Brand is Tunder Tiger.
If somebody know better. Thanks!
AZ
I found the servo . Some body knows if this is digital or analogical. It's humming under zero load.
Acoording seems like humming is ok for digital but it is a problem if you have that noice on a analogical. Nowing that I will buy a new one or not.
My Feedback: (158)
If the batteries are good that doesn't sound good as far as that servo goes
that kinda sucks if he sold you a truck with a bad servo
makes you wonder what else in his discription is untrue
good luck
A decent discount replacement servo would be a hitec 645,, a good sevo for the price
Good luck
good luck
Good luck
TX
Remove the horn on the steering servo and then see if it is making a humming noise. If not then something is stopping the servo from centering or reaching position requested. check the pillowballs for being too tight or other bind in steering. The stock servo saver can do this if wheels are on ground as it loads the servo from being weak.
LA
ORIGINAL: MGT_RaceX
AZ
Thanks guys for all your help!!!! I printed what you guys told me and used as a list.
I took the little control arm that connects to the servo off
And the servo still makes a electronic noise it is not the regular buzzing noise.
When I set the trim on the radio to 0 or move the servo the noise stops, but after that with no reason the noise is back
I tried the truck today and the steering servo is doing is job fine. It's just the noise.
If any body know some electronic trick. I will try that before I buy a new one. Thanks!
