why has thottle struck open?
i was using my tnx when the thottle stuck open,it,s fitted with a failsafe so can,t understand why,turn on the truck it,s fine then turn on the radio gear the thottle servo opens up full??????what,s wrong
RE: why has thottle struck open?
havn,t got reverse...but if i keep the brake on the servo returns to idle speed but as soon as i let go it revs straight up again
GA
If you can operate the throttle with your fingers than that eliminates the idle speed holding it open theory. Maybe you have you're servo reversed. If you can't find out what the problem is I'd just unscew the servo gorn and put it back on to where the throttle is set correctly.
its the servo reversing, happened on mine. there is usually a button on the TX and you want it the other way than wot it is at the mo.
