I will be doing motor transplants will most stuff fit??
I am going to put a SH .28 In my LST, will the Mach Flywheel and clutch bolt right up, and will this motor bolt right in?
Then I want to posibally put the Mach .26 and put it in my MGT. The same questions apply from the 1rst question.
or I thought about putting the Mach in the savage, and the nitrostar .25 in the MGT.
Is this all possible?? All motors are brand new.
Thanks for the help!!
RE: I will be doing motor transplants will most stuff fit??
the sh28 will fit the lst, you may need to raise the motor off of the mounts slightly to clear the chassis. A couple of washers between the engnine and mounts should achieve this, sure there is a thread coverng this motor in the lst on the lst forum
