Tnx plastic drivline fix.
GA
Well I found this info on another forum but decided to post it here to as there are a bunch of tnx's on here.
this mod will remove the stock plastic drive lines and replace them with metal universal axles, they weigh less and are alot stronger.
a little modifaction is requird, but nothing a dremel cant handle.
This is what you need.
http://www2.towerhobbies.com/cgi-bin...2&I=LXTW58&P=K
need 2x
http://www2.towerhobbies.com/cgi-bin...2&I=LXBCJ8&P=K
need 4x
http://www2.towerhobbies.com/cgi-bin...2&I=LXCTT3&P=K
need 2x
http://www2.towerhobbies.com/cgi-bin...2&I=LXCTT0&P=K
need 2x
I also put on the hpi rs4 header and mgt pipe.
Take a file and flaten the top of the dogbone, this keeps it from binding in the cup
you can see where i rounded the inner part of the knuckle, it actually gives you more stearing travel
stock hpi rs4 header before porting
Enjoy.
need 2x
need 4x
need 2x
need 2x
Enjoy.
RE: Tnx plastic drivline fix.
SHWEEEEEEET! i just broke one of my rear drive lines so this is a perfect mod. thanks for the info! btw... i can't see the links anymore. can you repost them or PM them to me. thanks! later.
GA
actually i ported the header to the max hole of the gasket. so I should need to. the gaskets the same size as the exghuast opening on the engine.
NY
[link=http://www2.towerhobbies.com/cgi-bin/wti0095p?FVSEARCH=LXCTT0&FVPROFIL=++]Need 2 of these[/link]
[link=http://www2.towerhobbies.com/cgi-bin/wti0095p?FVSEARCH=LXCTT3&FVPROFIL=++]2 of these[/link]
[link=http://www2.towerhobbies.com/cgi-bin/wti0095p?FVSEARCH=LXBCJ8&FVPROFIL=++]4 of these[/link]
[link=http://www2.towerhobbies.com/cgi-bin/wti0095p?FVPROFIL=++&FVSEARCH=LXTW58&FVPROFIL=++]2 of these[/link]
Those links should work.
Thats some nice upgrading you did. Let us know how they hold up. I just broke my plastic driveline yesterday, if it breaks again I will also be trying this.
BC, CANADA
This is what r/c is all about!! guys that try!! and then improve on the factory parts!! nice!! good job man! p.s no such thing as rtr
GA
OK, my advice for this mod is DONT. the stupid duracrap parts are weaker than the stock plastic. I have gone threw three of them and all of them fail at the u-joint. right now im working on making it so you can use the tnx ujoint pins instead of the pressed in duratrax pins. Ill get some pics up and show u what im talking about. if the pins didn fail, this things are great.
Hold off for now, Ill figure something out and post back
GA
oww, forgot to mention. I have called mip on several occasions. they say that its on there agenda in the next month or two to make aluminum cvds for the tnx. about time so if you can hold out for a little longer a much better hopup will be available
goody, cant wait....ill go for the NEm conversion get a TZ and those drivelines.....then the TNX would kick ass not toomuch power but definatly not to less ooooh boi im getting excited lol
