Swift/SHO truggy conversion?
Just how close is the MBX4 JT conversion from fitting the Swift/SHO buggy? The buggies are very close, if anyone has tried this please let me know. I really want a truggy in case my MGT cannot lay the smackdown like i think it will, but I do not want to spend big money to get one. I had a swift in the past, and liked it. The SHO buggy is basically free, so, I figured why not. Any info would be great.
BC, CANADA
RE: Swift/SHO truggy conversion?
TRY a gs sut centre diff 54t and a ofna 12t cb hd run dominator rims truck body and you got a truggy you may have to fabricate an adapter plate for the diff or it might drop in.TRUGGYS RULE!!
I actually have the GS unit with the 54 spur for a failed project I was trying with my old Terra Crusher. Do you think it will fit the center drive without a new top plate to clear the spur?
What do you suggest for body mounts?
BC, CANADA
IF you have a dremal or shop and some sheet metal anything will fit or you can use carbon fibre its harder to cut use sut body post $3 set = lots of sut rtr parts on ebay.
