Big block?
RE: Big block?
ORIGINAL: ctwitty
What is the biggest, most powerful motor that can be crammed into an LST? I'm looking for something reliable, fast and resonably priced.
I have the PEERFECT solution, it's called the MACH .26!!
An Losi had it figured out long before I did.
there's not a better comnbination of the attributes that you are looking for than the Mach..that's why it comes in the truck
WA
RE: Big block?
wow im shocked....nobody said the obvious.....the Collari 30 i believe is pretty reliable, and is obviously the biggest, fastest and most powerfull
PA
RE: Big block?
it just depends on how creative you are. line trimmer engines are cheap to buy, cheap to run, super reliable, and have enough torque to push an LST to about 70 mph if done right. here's my S-Maxx
PA
RE: Big block?
ORIGINAL: proxpilot
find me a way to mount one of those in my MGT will ya? he he he he
It would be easy to do a MGT. push the trany forward, make up new front and rear drive shafts, mount the engine sideways... and run a chain to the stock input shaft. (a #25 roller chain would be perfect) easy Actualy, I was going to use an MGT for my gasser conversion... but I got a good price on the S-Maxx.
RE: Big block?
When I said resonably priced I didn't mean that it had to only cost like $20, I just meant that I don't want to pay more for an engine than I did my truck. Where can I find out more on the Collari and Thunder Tiger engines? Dr Honda I like the line trimmer engine!
