RC Monster Trucks Discuss rc monster trucks in this forum
i got the MAMMOTH today
Old 06-10-2005, 02:02 PM
2000XLT
Default i got the MAMMOTH today
This thing really is BIG and HEAVY, i have a question about the engine break in. All the book says is to start the engine after priming it with fuel, let it run with the glow plug ingitor for 10 seconds, the remove it and start driving the truck around with short quick throttle bursts for 2-3 miniutes, then kill the engine, let cool for 10 min the turn the HSN in an 1/8 of a turn, and repeat the procedure again and keep doing so untill you have about 45 min of run time in.
Should i stick to the book strictly?
Old 06-10-2005, 02:18 PM
RenegadeRevo
RenegadeRevo's Avatar
Default RE: i got the MAMMOTH today
I would... that sounds like a heat-cycle method... one of the best methods out there.... let us know what you think of the Mammoth.
kiokentruck
go to globalhobby.com they can answer all your questions over there
Old 06-10-2005, 04:02 PM
hansdava
yea they are very helpful
Old 06-10-2005, 06:36 PM
Ovgron
Ovgron's Avatar
http://globalservices.globalhobby.co...orum/index.php
Old 06-10-2005, 07:16 PM
hybridstone
BIG N HEAVY? A mammoth? No waaaaaaaaaaaaay
Old 06-10-2005, 07:41 PM
RenegadeRevo
ORIGINAL: hybridstone
hehehee... isn't that what the name implies?
Old 06-10-2005, 10:56 PM
proxpilot
big yes! heavy... not too bad.
Old 06-10-2005, 11:02 PM
2000XLT
i do visit global often, i just want some of you guys and girls opinions on what parts need adjustment or tweaking out of the box.
Thank You Very Much
Old 06-10-2005, 11:25 PM
RCNewcomer
I am getting the mammoth st, the original mammoth is the bomb its insane speed and handling. Good Choice
Old 06-10-2005, 11:29 PM
RenegadeRevo
What I've heard out of the box... is shock tower braces... shimming the diffs.. and a roll cage...
Old 06-11-2005, 09:18 PM
2000XLT
I tried to start my mammoth for the first time today, after about 5 min someone called me and i had to go, so i finally got to try it again about 2 hours ago and the damn pull starter broke, did not even start. and to top it off i my glow ignitor did not charge after being on CHARGE all night, i tried with one of my friends ignitors. While i am at work tomorrow my friend is going to the hobby shop for himself and i told him to pick me up a shaft start and a better glow ignitor,I must say i was dissapointed after 2 attempts of starting the mammoth the pull starter broke
Old 06-11-2005, 11:07 PM
proxpilot
did ya have it hydro locked?
Old 06-12-2005, 12:15 AM
RenegadeRevo
That sucks... when I got my Revos... I kinda had the same problem... my batteries didn't charge enough... and neither wanted to start... so, I played with them for a while, and finally charged the batteries... and they started right up.... just keep going... sucks that the pull cord broke...
Old 06-12-2005, 03:50 PM
<conrad>
get a roto start alot more convenent i broke my pull start on like the 3 pull right when i got it lol so i got the roto it starts it up in 5 sec or less and i would suggest before u evan jump it 5 feet in the air that u get a shock tower brace but if u have extra money defintly the dadders rollcage it is the best support cage on the market for mammoth im picking one up in a week or so but good choice with the mammoth hope u like it
Old 06-12-2005, 03:53 PM
RenegadeRevo
stock up on A-arms, too... that seems to be a big one....
Old 06-12-2005, 04:07 PM
<conrad>
yep definantly ur gona need some extra a-arms unless u get the aluminum ones and ur set
Old 06-12-2005, 08:49 PM
2000XLT
ok so today i got the roto start back plate and a shaft so i can use a cordless drill to start the engine, My question is do i need to put any lube on the 2 gears inside the backplate?
Thanks, and thanks for the othe replies!!
Old 06-12-2005, 09:05 PM
<conrad>
i dont think u do i never put any lube on mine and its work perfect
Old 06-13-2005, 08:28 PM
2000XLT
ok so i got the mammoth started today but it will not move forward, someone suggested its the linkages, i look at them and then looked at the book and the linkages are set differently, can someone post a pic of how the are supposed to be set?
Old 06-13-2005, 08:41 PM
proxpilot
also look and see if your set screws are tight on your center drive shafts.
Old 06-13-2005, 08:51 PM
RenegadeRevo
Wow... all these problems out of the box? I didn't think the Mammoth was that bad... my friend didn't have those problems... maybe you should take it back and exchange it... Lemon law, or something (too bad it doesn't work... and not even sure if that's a "law" in your state... AZ has a Lemon law, but it is only for 1:1 cars...)
Just keep going... hopefully you will like it once you get it started... it's definitely fast.
Old 06-13-2005, 08:55 PM
2000XLT
ok i think i know what it is, i forget the name but one of those small round stoppers with a set screw is set wrong, when the throttle is opened the brakes are also being applied, so i have to adjust this. how ever i would still like a pic of the exact set up if possible
Old 06-14-2005, 12:09 PM
<conrad>
this is what u do u turn ur truck on then loosen that stopper thing now pull the thing in the carb about a milimeter maybe 2 out now tighten the stopper so it stays at one to two milimeters now set ur low speed needle so when u hit the brakes ur carb thing dosent move and then ull no u have it set up right ill send a pic latr today as soon as my camera comes in.
Old 06-15-2005, 08:38 AM
2000XLT
did you get your camera yet?? XTMBASHER
